oil pressure gauge is pegged
Old Apr 10, 2007 | 08:36 PM
Janko98Z's Avatar
Default oil pressure gauge is pegged
I just finished my ls6 manifold install on my 98 and now my oil pressure gauge is pegged. I was careful with the brake booster hose but it ended up pulling pretty hard on the top connector wires. I unplugged the connector and both wires look like they're still secure. Somehow it must be grounding out. Anybody else had this problem?
Old Apr 12, 2007 | 10:46 PM
Janko98Z's Avatar
I found the problem. One of the wires going to the oil pressure sender was stretched so far the wire broke inside the insulation. I just cut out the connector and shortened the wire and spliced it back in.
Old Apr 12, 2007 | 11:07 PM
98Camarod's Avatar
I was going to say it is either broken or there is a wiring issue somewhere. Glad to see you got it fixed.
