LS2 mani/TB
Old Apr 14, 2007 | 12:03 PM
SSWS6's Avatar
Default LS2 mani/TB
Ok forgive me if this has been discussed before, but I would like to know if a LS2 manifold/TB assembly will bolt onto my LS1. And if so, what and how much work is involved? I can't really go with aftermarket parts in this case because of smog here in Cali (visual inspection). Plus the LS2 mani/TB flows plenty of air so correct me if I'm wrong but it should be adequate for a 450-500rwhp car which is my eventual goal. And yes I know that tuning will be required. And I will be eventually stepping up to aftermarket heads but for now I'm running stockers.
Old Apr 15, 2007 | 05:38 PM
WILWAXU's Avatar
Your stock LS6 intake will make better power.
Old Apr 21, 2007 | 01:33 AM
tnsyty's Avatar
Would this be a good option for a 98 vette that has the old LS1 style intake on it? I am pretty sure I have seen the LS2 manifolds cheaper than some LS6 manifolds. Plus i can use the 90mm TB with an adapter that has been made for the LS1 car. What does it take to make it work?
Old Apr 23, 2007 | 02:50 PM
faster_n_you98's Avatar
i put the ls2 intake with a holley 90mm tb on mine and love it. i really dont see how an ls6 intake flows better than the 90mm ls2, but i dont know. i noticed a good addition of power and even a difference of the sound of the engine in the engine bay. i wouldnt change a thing.
