FAST MAP Sensor?
Old Apr 14, 2007 | 12:05 PM
Johnie_West's Avatar
Default FAST MAP Sensor?
I need to replace my MAP sensor. I have the FAST intake. Do I have to have the FAST MAP or is the factory one just as good? FAST offers too many varieties and I don't even know which one to get. 1,2,3 or 5 bar.
Thanks in advance for any help
Old Apr 14, 2007 | 12:49 PM
Dmoney's Avatar
Factory is fine..........
Old Apr 16, 2007 | 10:05 AM
radkon's Avatar
Factory is fine but make sure you get a new gasket with it. The FAST map hole seems a little bigger than the stock intake's and a lot of people have isses with reusing the stock gasket with it.
Old May 1, 2007 | 02:35 PM
aNuBiS's Avatar
Bump to find out what new gasket this is, or what the part number is.
Old Jan 13, 2008 | 05:11 AM
qwik_ss's Avatar
bump because I want to know what gasket do you replacce with??? Any help would be apreacited
Old Jan 13, 2008 | 07:58 AM
Michael02hawk's Avatar
16212460 MAP sensor w/Seal
16194007 Seal only
Old Jan 13, 2008 | 10:05 AM
allthrotle's Avatar
This is true, when I reused my old factory map sensor the gasket was a little worn and the hole in the fast manifold is a tad bit bigger so I ended up with a vacuum leak. I had to pull the manifold and replace the map with a new gasket, actually I had a brand new map laying around and I dont know why I didnt use it the first time.
Old Jan 13, 2008 | 01:25 PM
Black Sunshine/ 00SS's Avatar
The FAST map hole is way to big, unless you get the new revised intake, which will say "revised" right at the MAP hole. I found that even with a new gasket, it still was too loose. Best bet would be to get some epoxy and fill in the hole let it dry, and redrill so that it is a nice snug fit.
Even with the revised intake, the hole was still not a snug fit. So, I put some silicone around the MAP and let it sit overnight before installing.
 Michael S. Palmer
