how well does this work?
Old Apr 15, 2007 | 09:44 AM
fuseone's Avatar
Default how well does this work?
how does the bump stop hanger work does it fix the ypipe from banging against the floor well?
Old Apr 15, 2007 | 09:55 AM
beaSSt's Avatar
If you're talking about the Mufflex hanger it fixed my banging perfectly.
I got under the car to see where the least clearance was. I used a pry bar to move the exhaust down about 1 - 1.5" at the tightest spot and temporarily put an old exhaust hanger rubber in between the y-pipe and that spot.
I then put the Mufflex on and got it tightened. Then I removed the exhaust rubber I had put in between the pipe and the floor and I have not had problems since.
Old Apr 15, 2007 | 11:26 AM
fuseone's Avatar
you think if i get better motor mounts and tranny mount it should fix the problem? because i still got the factory mounts in
Old Apr 15, 2007 | 11:38 AM
Tainted's Avatar
you amy or amy not. some people still have banging issues with new mounts
Old Apr 15, 2007 | 11:43 AM
fuseone's Avatar
well ok what would be the best way to stop the ypipe banging
99blancoSS's Avatar
Fix it right. The mufflex is a bandaid. Spongy soft factory mounts are the issue. Replacing the driver side fixed my y-pipe bang, I've since done the other side as well as the trans mount. Let it go long enough and it will be your headers banging on acceleration and deceleration.
Old Apr 15, 2007 | 11:45 AM
fuseone's Avatar
ok what are some good mounts to replace it with?
Old Apr 15, 2007 | 11:46 AM
fuseone's Avatar
and also what do you mean am i amy or not amy?
 Michael S. Palmer
Old Apr 15, 2007 | 11:47 AM
99blancoSS's Avatar
prothane has worked well for me. Got all mine from Thunder but most sponsors carry them.
Old Apr 15, 2007 | 11:49 AM
01pewterbird's Avatar
The mufflex didn't work for me. It would if I tacked it on, but I don't have a welder. You can tighten down on that thing as much as you want but it slips and doesn't hold it's position.
Old Apr 15, 2007 | 11:51 AM
fuseone's Avatar
ok so 01pewterbird how did you fix the problem?
Old Apr 15, 2007 | 12:06 PM
lol, I didn't. I stuck some heater hose wrapped in header wrap in-between to stop the actual banging, so it still hits but it's cushioned now. Although I think my y bangs in a different spot then most, Mine practically touches all the time right where the collector goes into the cat, so that first floor brace. I specifically told Stainless Works this had been a problem with others I had spoke with and to make a note while making my headers to look out for this, but they obviously didn't . The headers themselves are the actual problem, primaries have to much bend in them, angling the collector up, making it way to close to the floor. I want to add poly mounts to fix the problem once and for all but I'm scared they will raise the motor some and make the problem even worse
Old Apr 15, 2007 | 12:10 PM
c0ncEpT's Avatar
Motor mounts are the only to fix it, Like stated before everything else is just a band aide. I used some heater hose and it has worked well for me. Mounts are not expensive at all, its just hard to find the down time to install them
Old Apr 15, 2007 | 03:04 PM
fuseone's Avatar
where is a good place to buy some good motor mounts and a tranny mount because if im gonna do it im gonna do them both to be sure
Old Apr 15, 2007 | 03:11 PM
fuseone's Avatar
like would these be good mounts to use?http://www.ws6project.com/user_stor/...7dca88ecf44228
Old Apr 15, 2007 | 03:23 PM
MdFormula350's Avatar
yes prothane's is what i recommend and that a nice package they have their.
Old Apr 15, 2007 | 03:28 PM
fuseone's Avatar
what are they made out of Polyurethane?
Old Apr 15, 2007 | 03:37 PM
greatskiiiier's Avatar
lmao
It may or may not, it was a typo on his part
Old Apr 15, 2007 | 05:33 PM
fuseone's Avatar
yea but are those mounts Polyurethane. and should that stop it from banging?
Old Apr 15, 2007 | 06:38 PM
fuseone's Avatar
