View Poll Results: Would you buy a less expensive SLP style bellow at $40 or $35
yes
98
60.12%
no
65
39.88%
Voters: 163. You may not vote on this poll
Smooth Bellows instead of Fernco
Old Apr 17, 2007 | 12:44 PM
staringback05's Avatar
ive just left the stock bellows on it....aside from the looks...its not worth the money to add one of those slp bellows
Old Apr 17, 2007 | 01:10 PM
waterbug1999's Avatar
For me, I had the N20 nozzle in the bellows and then decided to go to the plate system. So, I had to get another one.
Old Apr 17, 2007 | 01:14 PM
NC98Z's Avatar
You don't make anymore horspower with any of them so I'm sticking with GM stock. Hell you can almost get 10 gallons of gas for $35.This week anyway.
Old Apr 17, 2007 | 06:25 PM
5_02ls1's Avatar
i wouldnt buy either espeacialy somthing designed to connect sewer lines.spend the money elsewere the stock peice looks good enough for me and there is no way its restrictive
Old Apr 18, 2007 | 01:31 AM
Ripper415's Avatar
i wouldnt just because i know it gives at most 1hp. so while a $70 per hp mod sucks, a $40 per hp mod sucks almost as bad. i fernco is less than $5. the absolute most i'd pay for a specialty designed piece that would easily fit on the first time w/o having to boil/cut it would be like $10....the same price as a ticket to see redline in NY lol.
Old Apr 18, 2007 | 12:06 PM
99blancoSS's Avatar
Me too. So now I have the option of the factory bellow which I still have or a Ferno or the SLP unit or one of many silicone hump hoses off the web that arent really made for it and cost anywhere from $20-$45. I like the SLP unit. Its a quality peice. Hell you could use 3" pvc as well if you wanted to and hard pipe it. I've got far to much into my car to open the hood and see a common plumbing part that may or may not crack my lid. $35 might be a real do able price. Anyone seriously interested pm me and lets see what we can do.
Old Apr 18, 2007 | 01:47 PM
marv's Avatar
I tried the Fernco setup, but I couldn't get everything to fit/line up correctly...ended up picking up another smooth bellow from a friend for real cheap...
Worked like a champ...
Old Apr 18, 2007 | 02:58 PM
One thing to keep in mind is, make sure that SLP bellows comes in the 4" (90MM) for your set up.
Old Apr 18, 2007 | 03:02 PM
02silvaZ's Avatar
had the fernco, didnt do ****, went back to stock accordian, its good enuff for me
Old Apr 18, 2007 | 03:40 PM
99blancoSS's Avatar
They are all the same size on the outside. The stock bellow and 3.5 x 4. The SLP is 3.5 x 4 and they both fit. The accordian is tighter but fits on the 90 as does the SLP
Old Apr 18, 2007 | 09:26 PM
NSTY WS6's Avatar
If you need something with a slight bend, I noticed several types/sizes/bends on the site waterbug posted, look through there.
Old Apr 18, 2007 | 09:39 PM
  #32
99blancoSS's Avatar
I have/did, even spoke with them about it.
Old Apr 18, 2007 | 09:48 PM
  #33
From looking at your pic (link below), I think you will have to cut the SLP and/or the one from the link I posted. And I am betting that you will need to cut one side of the bellows at an angle to get proper fit. I see how your lid is angled down and the the TB is straight. But, I am sure you know this so good luck.
http://www.fquick.com/images/vehicle...jpg?1170870128
I know my pic is not the best angle but here is the way mine is. N20 wiring is not done yet either..Just a mock up for now.
http://www.geocities.com/jody_abbott...csagain005.JPG
Old Apr 18, 2007 | 10:01 PM
  #34
99blancoSS's Avatar
Nice tool rack ..lol Yea, they all have to be cut for proper fit. What I'm looking to have made will need to be cut as well but it will work with a maf or without it. It will be long enough to use for just about any application. Problem is it keeps getting to be more and more money to produce. Because of the angle I have to buy the tooling and then making it 7 inches instead of 6 costs me as well.
Cant wait to get my plate from Dave. He's making it special for my application. Dual stage with fittings in front and back.
Old Apr 18, 2007 | 10:11 PM
  #35
That'll look killer. Post up pic when done..
I have yet to use my Nitro Dave's plate. The car has been sitting over the winter broke and finally got her fixed and I should be on the road tomorrow beatin the **** out of her..
Good luck.
Old Apr 19, 2007 | 08:04 AM
  #36
JayBirdWs6's Avatar
I did the frenco thing for awhile and I thought it was to stiff even after trimming it to fit. I couldnt get my lid to fit right because of the stiffness. I said screw it and went with a slp bellows and its great.
Old Apr 19, 2007 | 10:20 AM
  #37
Redlinez's Avatar
Waterbug1999, you probably already know, but you're missing nuts on both front strut bolts.
I love my Fernco so much I left the cool purple label on it.....I would go with the smooth bellows if you come across a good deal on used stuff or something like that.
Old Apr 23, 2007 | 03:27 PM
  #38
faster_n_you98's Avatar
he probably just took off his strut tower brace.
Old Apr 23, 2007 | 05:01 PM
  #39
Yea, I left it off as I was still working on the motor.
Old May 2, 2007 | 11:00 PM
  #40
boondiggys's Avatar
im using the slp version, because i had to modify the lower part of my stock airbox for my lid to attach.
