Throttle body Part# question
Old Apr 16, 2007 | 10:50 AM
EDS01SS's Avatar
Default Throttle body Part# question
Does anybody know the part# for the throttle blade seal that sits under the throttle position sensor? Mine is missing out of my throttle body and GM says there is no replacement but that has to be B/S. Every part has some sort of a number.
Old Apr 16, 2007 | 11:59 AM
Torque_Wrench's Avatar
17082049 is the part # to your IAC Valve seal. The IAC Valve is right beside the TPS Sensor. If the IAC Valve seal is the same size as the TPS Sensor...then this will work.
Otherwise, you'll have to buy a new TPS Sensor. That's the only way the seal comes...with the sensor. But look at the IAC and see if they are both the same size.
