Bleeding the Fuel System
Old Mar 11, 2002 | 07:06 PM
NoGo's Avatar
Default Bleeding the Fuel System
Do I need too? When changing the injectors, or for that matter, anytime you break the fuel system at the block, is there a procedure that must be done prior to starting.
I see there are several service ports entering the fuel system near the injectors. Do I need to bleed fuel up to the injectors prior to starting?
Any help would be appreciated.
Thanks,
Kevin
Old Mar 11, 2002 | 11:12 PM
Slowhawk's Avatar
LS1Tech Sponsor
Default Re: Bleeding the Fuel System
No, you don't have to bleed it.Just turn the key on-off a few times to build up the pressure.
Old Mar 11, 2002 | 11:46 PM
Plan B's Avatar
Thats right. It may idle rough for the first few seconds. It will come good though.
Old Mar 12, 2002 | 12:05 AM
Colonel's Avatar
Yup, just turn the key on and off a few times to fully pressurize the system.
Old Mar 12, 2002 | 06:27 AM
NoGo's Avatar
Thanks
<img src="gr_stretch.gif" border="0">
<img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
