IN-LINE PUMP ??
Old Mar 1, 2002 | 10:32 PM
wicked 98z's Avatar
Default IN-LINE PUMP ??
Where can I get a IN-LINE PUMP at? What would be the best one? Which would put out the most HP without changing the intank? Or would it be better to install a intank and inline?
I seen speedinc has a the 255 and they have been over over 123 mph with this pump. Should I skip this one if I have traped over 123?
Thanks
Albert
Old Mar 4, 2002 | 05:42 PM
wicked 98z's Avatar
Default Re: IN-LINE PUMP ??
TTT?
Can someone PLEASE help me. I need to know what to order.
ALbert
Old Mar 5, 2002 | 08:45 AM
wicked 98z's Avatar
TTT
Old Mar 5, 2002 | 09:44 AM
Matt98SS's Avatar
replacing both the intake and adding an inline is the best way to do it. but the inline is just fine. you can use a Vortech T-rex or the holley EFI fuel pump inlines in your car.
Old Mar 5, 2002 | 11:12 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Intank is a lot harder to change.
But it's the most logical one to get.
Old Mar 5, 2002 | 11:28 AM
Magnus's Avatar
LS1TECH Sponsor
The intank fuel pump install is fairly straight forward. It should take about 8 hours to do as well taking your time.
The only difficulty with the intank pump swap comes when you are ready to drop the tank itself. It can be a pain to wiggle the tank out of the car with the long filler neck. I had to bend my filler neck to get it out.
Also, if your going to do an intank swap, be VERY careful with the fuel level sender assembly, try not to damage/bend it in any way or you'll have to remove the tank again to fix it.
Old Mar 5, 2002 | 11:48 AM
Bad Habit SS's Avatar
get a NOS inline pump, Thats what im running
Old Mar 5, 2002 | 01:16 PM
wicked 98z's Avatar
[quote]Originally posted by Bad Habit SS:
<strong>get a NOS inline pump, Thats what im running</strong><hr></blockquote>
I was thinking about getting that one. All I need is to make sure I got enough fuel for a 100 shot of n2o
Albert
 Michael S. Palmer
Old Mar 5, 2002 | 01:31 PM
F1's Avatar
F1
[quote]Originally posted by wicked 98z:
<strong>Where can I get a IN-LINE PUMP at? What would be the best one? Which would put out the most HP without changing the intank? Or would it be better to install a intank and inline?
Thanks
Albert</strong><hr></blockquote>
I went 11.55 @ 126.51 with a 2.1 60ft with no problems.... Actually the car was running rich… 02’s would not go below 940’s…
