LS1 "normal" noise
Old Mar 14, 2002 | 03:07 PM
PewterFormula02's Avatar
Default LS1 "normal" noise
For all those people who bought a brand new LS1 F-body or vette and have noticed a tapping or ticking or a similar noise to which the dealer said was normal please goto the link below.
Heres the link to the post http://www.ls1.com/forums/showthread.php?s=6b5eb76ebdfa2deda 41155e14d72a7f5&threadid=60315&perpage=15&pagenumb er=1
So if anyone else has an LS1 with engine problems at was not due to mechanical over rev. be sure to voice your concern
Old Mar 14, 2002 | 05:31 PM
Z2802's Avatar
Default Re: LS1 "normal" noise
My Z28 makes noise when it's cold, it sounds like a collapsed lifter to me (old school experience). Doesn't sound like a rod or bearing knock to me, it's solid like a lifter, not hollow sounding. The noise seems to go away once it's warmed up. I may go back to 5w-30 at my next oil change and see if that helps, I'm running 10w-30 right now. The car is only 8 months old and shouldn't have any odd noises at this point, it's had regular oil changes and for the most part I baby her.
Maybe we could get Marvin to raise some hell for us too!
Old Mar 14, 2002 | 07:47 PM
well either tonight or tomorrow that petition will be on a hosted site. Keep in touch with the link above for further details.
Old Mar 15, 2002 | 06:02 PM
It's now up.
http://www.ls1camaro.net/ls1knock/index.asp
Old Mar 15, 2002 | 09:13 PM
PewterZ's Avatar
The ticking noise is normal...Its the exhaust flow. It's even worse on the 99-00 cars with the EGR
Old Mar 15, 2002 | 10:26 PM
Skelton's Avatar
My 01 has a definate tick at idle which is more pronounced under cold start but its far from a knocking noise. My 00 Ta made the same noise but not quite as pronounced. The only complaint I have is the damn pcv sucking oil like 5 dollar hooker.
Old Mar 16, 2002 | 09:54 AM
DriveATransAm's Avatar
i dont really hear the noise on my 01. maybe im just oblivious to it, or its not there <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
at any rate, would there be any potential problems if there were overboard cylinders? my cars running really nice and i dont want to start over with a slow engine <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Mar 16, 2002 | 09:58 AM
MaxHax's Avatar
02 Z28 no ticking.
Old Mar 16, 2002 | 10:15 AM
Fletch's Avatar
I hear this noise from start up to shut down. Sometimes it goes away for a few minutes and then when I'm feeling sorta better about the problem it shows up again. VERY VERY ANNOYING <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
Old Mar 17, 2002 | 08:05 AM
LuciferSam's Avatar
I have a 2000 TA with the knock at startup then a slight tick at operating temp. I did have an oil pump failure at 8600 miles which the dealer replaced but I don't think thats the cause of my knock.
Old Mar 17, 2002 | 08:53 AM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Are you guys hearing piston slap? I have really bad piston slap on cold start-up, but it's gone once it gets up to temp.
__________________
Old Mar 17, 2002 | 08:43 PM
LS1 JAY's Avatar
Does anyone have a sound clip of piston slap? now I'm curious!
Old Mar 17, 2002 | 10:16 PM
02WS6's Avatar
My 02 WS6 had some ticking when cold. But after I made two oil changes, it has gotten more quiet and less noticeable. Piston slap, from my experience with traditional Pontiac motors, is a more deeper sound that seems to originate deep in the motor. Many times you can hear it better from under the car. A rod knock usually has a double knock to it and often shows a unstable oil pressure. The ticking noise I hear from my 02 sounds like a small amount of over lash in the rockers that may be caused by a sticking lifter. But once oil temp and engine temp increases, the noise vanishes. I would get a second and third opinion prior to having a motor yanked for piston slap, or anything else for that matter.
Old Mar 17, 2002 | 10:26 PM
02WS6's Avatar
A way to tell if its piston slap is to retard the timing while the engine is running. This will reduce the load on the piston and quiet the slap some or completely. Piston slap is more common in engines with forged pistons. Forged pistons require more cylinder wall clearance than cast because the expand more when hot. Consequently, once the motor is warm the piston slap will be more quiet or stop completely. Another way to aid in diagnosis is to kill the cylinder with the excessive slap and this will reduce the load and stop the slapping.
Old Mar 18, 2002 | 01:22 PM
85transamtpi's Avatar
Just curious guys,
I do not have this problem but have you guys tried to use a scan tool durring the sound? Wouldnt the K.S. pick up any sort of internal noise and register it as a knock? I know on my old tpi motor that stupid thing will pick up something that I sure couldnt hear and call it knock. Just a thought.
Doug
Old Mar 18, 2002 | 11:20 PM
BADZ's Avatar
Moderator
The GM guy's call it cold start tick and have had to replace the whole entire ls1motors for upset customers who complained about the noise. I know because I bought one entire ls1 motor for 600.00. It was a warranty motor because someone complained about the cold start tick (PISTON SLAP) deal.... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I will buy them all day long for that and use them in my car.... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Mar 19, 2002 | 01:28 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by BADZ:
<strong>The GM guy's call it cold start tick and have had to replace the whole entire ls1motors for upset customers who complained about the noise. I know because I bought one entire ls1 motor for 600.00. It was a warranty motor because someone complained about the cold start tick (PISTON SLAP) deal.... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I will buy them all day long for that and use them in my car.... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Weird, my dealer won't do anything about my motor knocking. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Old Mar 20, 2002 | 04:38 PM
patSS/00's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by RPM WS6:
<strong>I get the cold start piston slap. Mine is really weird though, in that it won’t do it right away. But right about 120 deg (coolant temp) or half way warmed up it will start to do it, then once it fully warms up the noise goes away. Or, if I start driving it before it stops, then just bringing the revs up to move the car (3500 stall <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> ) will make the noise vanish and not return when dropping back to idle. I see no movement at all in the oil pressure gauge when this noise happens.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">My 2000 does exactly the same thing, except it maybe starts a little sooner temp-wise. If I drive up our road to the stop sign (20 seconds), the noise is gone. This started around 2K miles. I should say it _did_ do this, since lately the noise has not appeared - I don't think I've heard it since the last oil change, where I used 1/2 10W30 synthetic and 1/2 5W30 dino oil. The other thing about this noise is I'm pretty sure it's not piston slap, since I've also heard that sometimes (but not most of the time) after a cold start, and that's a different sound, more muted and hollow sounding.
<small>[ March 20, 2002, 04:40 PM: Message edited by: patSS/00 ]</small>
Old Mar 21, 2002 | 12:41 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
I get the cold start piston slap. Mine is really weird though, in that it won’t do it right away. But right about 120 deg (coolant temp) or half way warmed up it will start to do it, then once it fully warms up the noise goes away. Or, if I start driving it before it stops, then just bringing the revs up to move the car (3500 stall <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> ) will make the noise vanish and not return when dropping back to idle. I see no movement at all in the oil pressure gauge when this noise happens. My ’99 Z also did this in almost the same manner. I’m not worried about it though. I have bigger issues to concern myself with. I would buy a spare motor for $600 to if this was the only thing wrong with it <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> Mine’s done it since new and never gotten any worse or better <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Jun 21, 2011 | 07:19 AM
TooFaSS4u's Avatar
Default Engine ticking
Just picked up an 02 SS with 25,000 miles immaculate condition a few months ago and I have noticed a ticking noise coming from the engine at idle and at speed not accelerating. It has always had Mobil 1 10/30 fully synthetic oil and Mobil 1 oil filter. I don't think it's anything damaging but it's annoying and with it having such low miles I wouldn't think it be making any noises like that. Any help/suggestions would be greatly appreciated
