I'm installing FLP long tubes and exhaust, pointers please
Old Mar 19, 2002 | 01:37 AM
u8dusst's Avatar
Default I'm installing FLP long tubes and exhaust, pointers please
Im going to be doing with my buddy all in one shot. Anything I should know? Shortcuts, kill two birds with one stone kinda things? Thanks a lot. And what parts I will need to buy from the autp parts store that dont come with the long tubes and exhaust. BTW, I will be running cats.
Old Mar 19, 2002 | 08:28 AM
Slowhawk's Avatar
LS1Tech Sponsor
Default Re: I'm installing FLP long tubes and exhaust, pointers please
Here's alist you need before install:
New factory manifold gaskets(or reuse old)
Restrictor plates for air valves.
02 wiring extensions.1'
Sawzall or something to cut stock exhaust back.
Torque wrench-18ft/lb's for header bolts.
New plugs-while they will be out.
Patience
Make sure the car is at least 2-2.5' off the ground to get the headers in.
I have some pics.E-mail me if you want them ie hight ect.
Old Mar 19, 2002 | 10:56 AM
TA_2001's Avatar
here is a couple of things I found..
http://www.ls1info.com/article.php?sid=23
and another
http://www.ls1info.com/article.php?sid=55
Old Mar 19, 2002 | 10:57 AM
MIGHTYMOUSE's Avatar
1st remove all the header bolts (removing some pass. coil packs will help)
remove spark plugs
lift car and remove exhaust, (wd-40 ahead of time will help)
get the car as high up on normal jackstands as you can get.. both go in from the bottom
you will probably need room on the drivers side so go ahead and change the oil at the same time, removing the oil filter and drain plug
install new plugs while you are at it.
you may have to cut down the head of the drain plug to allow it to be removed in the future with the headers in place.
you may have to cut some off of your cat back I-pipe to fit behind the flp y-pipe. an inch or so. check this before you lock down any clamps
push aluminum foil in the notch on the clamps if you can't get them to seal.
Old Mar 19, 2002 | 11:14 AM
Slowhawk's Avatar
LS1Tech Sponsor
Also remove the heat shield over the clutch line for easy installing.
You might have to grind down the stearing bolt and nut.If I knew this before everything was done I would of dimpled the header tube instead.
