Anyone running the Aeromotive fuel rails?
I've heard multiple response on whether or not the Aeromotive 5.0 rails work on the LS1 motors or not. Anyone know for sure? Is anyone running these right now?
TIA
TIA
From what I understand, the angle of the rails and injector spacing is correct, but the mounting tabs are in different locations from the LS1, and must be modified to fit.
I think Nick@ARE sells modified stock rails that support quite a lot of fuel flow/hp, so that may be something you want to look into as well...
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by GeorgeC:
<strong>From what I understand, the angle of the rails and injector spacing is correct, but the mounting tabs are in different locations from the LS1, and must be modified to fit.
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yep
center to center spacing is the same, as well as injector angle.
But, the mounts need to be fabbed to make them work.
