Who has FLP LT headers and cut outs ?
What size are the FLP LT header tubes, 2.5", 3.0",or 3.5"? Where is the best place to put the cut outs? I was thinking right behind the orps-cats but I'm not sure there is enough room for a cut out right before the tube turns inboard towards the Y pipe on the passenger side and I am thinking they might hit the floor boards. Where did you put them? let me know, thanks.
Mark
Are you referring to the y-pipe or the primary tubes on the headers? The y-pipe is 2.5". I had Nick at Nick's Muffler in Plano build me dual custom cutouts on my '98 T/A, and he did an EXCELLENT job! He built them just before the y-pipe turns to merge at the collector. He built them so that the exhaust will be able to shoot straight out of the y-pipe. It was a trick setup. The downside is that he charges $75 per cutout, but he'll do a fantastic job so that it won't bang on the floorboard of the car. It will also last a lot longer than the standard cutouts that you can get from Summit. Those typically warp some over time; mine did when I had one on my T/A way back when.
The car is at FAStech now, I told Sean to have 2 of them put on while it's there. I'll call him and tell him to have Nick build them for me and get them installed while it's there.
Mark
---also, this is kind of a redundant questions, but without valve work, something happen without backpressure like burned out valves or something?
<small>[ March 26, 2002, 11:35 AM: Message edited by: R U A LS1 ]</small>
Mark
