Hesitation a 3000rpm
<small>[ March 27, 2002, 03:36 PM: Message edited by: knwilson ]</small>
Silver.. you'll find this place IS NOT like ls1.com <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
<small>[ March 27, 2002, 05:33 PM: Message edited by: WILWAXU ]</small>
someone thinks it could be the torque managment is set to low, and need to be turn off.
but if you fine out let me know "thanks
Mods
Pulley
airbox
4.10
ported MAF
flowmaster muffler
TB bypass
160 degree therm
<small>[ March 28, 2002, 08:22 AM: Message edited by: HumpinSS ]</small>
Bulletins for 2001 Pontiac Firebird V8-350 5.7L VIN G SFI
Service Bulletins
TSB Number Issue Date TSB Title 01-07-30-030 OCT 01 A/T - Harsh 1 to 2 Upshift Diagnostic Information
01-05-23-010 OCT 01 Brakes - Rattle Noise From Rear of Vehicle
00-06-04-011A OCT 01 EVAP System - Monitor Strategy
01-06-01-023 OCT 01 Engine - High Oil Consumption
01-00-89-015 OCT 01 PDI - Dealer & Production Installed Accessories
01-08-51-003 OCT 01 Vehicle - Interior/Exterior Anti-Corrosion Materials
01-00-89-014 OCT 01 Warranty - Standard and Optional Administration Process
01-04-20-004 SEP 01 Drive Pinion Flange/Yoke/Oil Seal - Replacement
01-04-17-003 SEP 01 Propeller Shaft & Rear Drive Axle - System Diagnosis
01-00-89-013 SEP 01 RKE Transmitter - Correct Use of Labor Operation R4490
00-00-90-002A SEP 01 Tires - Recommended Inflation Pressure Specifications
01-01-39-003 AUG 01 A/C - Screen Filter Kit
01-08-46-004 AUG 01 Cellular Phones - Operating Characteristics
01-08-46-006 AUG 01 OnStar(R) Antenna Coupling - Replacement Procedures
01-00-89-011A AUG 01 Technical Assistance Form - New
01-01-38-006A JUL 01 A/C - Proper Flushing Procedures
00-01-38-009A JUN 01 A/C - Factory Added Leak Detection Dye
01-00-89-010 JUN 01 Diagnostic Worksheet - Usage
99-06-03-010A JUN 01 PCM/BCM Replacement - DTC's B001/B1271/B1780 Set
01-09-40-002 JUN 01 Seat Belt System - Collision Replacement Guidelines
99-01-39-004A MAY 01 A/C - Odor Emission in Hot Weather
01-00-89-009 MAY 01 Key/Key Number/Security Chip - Replacement
01-08-46-001 MAY 01 On Star Module - Required Reconfiguration
01-07-30-021 MAY 01 Park/Neutral Switch - Connector Hard to Remove
01-07-30-012 APR 01 A/T - 4L60 E Revised Valve Body/Spacer/Gaskets
01-07-30-020 APR 01 A/T - 4L60E Valve Body/Spacer/Gasket Kit Reference
99-07-30-020A APR 01 A/T - Service Procedure Changes
01-08-97-001 APR 01 Homelink - Transmitter Test Kit
01-08-44-005 APR 01 Radio Display - Error Code Diagnosis/Repair
01-00-89-08 APR 01 Service Information 2000 - Campaign Access
01-02-32-004 APR 01 Special Tools - Power Steering System Analyzer
01-08-58-002 APR 01 Windnoise/Water Leak - Diagnostic Guide
01-07-30-010 MAR 01 A/T - Torque Converter Replacement Guidelines
01-02-35-001 MAR 01 Air Bag - Squeaks When Turning Steering Wheel
01-06-01-011 MAR 01 Engine - Oil Consumption Guidelines
01-08-51-001 MAR 01 PDI - Transit Protection Coating Residue On Paint
01-00-89-006 MAR 01 Technical Service Bulletins - Summary
01-08-42-001 FEB 01 Exterior Lamps - Condensation & Replacement Guidelines
01-00-90-001A FEB 01 Rear Axle Lubricant - Recommended
01-07-30-007 FEB 01 Torque Converter - Bolt Design Update
00-00-89-15A FEB 01 Warranty Administration - Repair Order Documentation
01-03-10-001 FEB 01 Wheel Lock Wrench - Proper Location During PDI
01-08-48-001 FEB 01 Windshield Reveal Molding - Squeak Noise
01-01-38-001 JAN 01 A/C Compressor - Shaft Seal Replacement
01-00-90-001 JAN 01 Rear Axle - Lubricant Recommendations
00-08-48-005 DEC 00 Glass - Distortion Explanation
00-08-57-004 DEC 00 Rear Hatch - Water Runs Out of Corners
00-00-89-029 DEC 00 Vehicle - Warranty Labor Time Guides Update
99-00-89-019A DEC 00 Warranty - Parts Return Program
00-00-89-027 NOV 00 Interior - Odor Elimination Product
00-08-48-003 NOV 00 Stationary Glass - Installation Method
00-03-10-006 NOV 00 Tires - Radial Force Variation
00-00-89-025 NOV 00 Vehicle - Labor Time Updates
00-00-89-023 OCT 00 Labor Time Guide - Update
00-01-38-007 SEP 00 A/C Performance/Leaks - Diagnostic Procedure
00-00-89-020 SEP 00 Labor Time - Updates September 2000
00-06-01-016 AUG 00 Engine - Aluminum Thread Repair Kits
00-06-02-006 AUG 00 Engine Coolant - Information
00-00-89-017 AUG 00 Labor Time Updates - August 2000
00-00-89-014 JUL 00 Labor Time Updates - July 2000
00-00-89-012 JUN 00 Labor/Time Guide - Updates
00-06-04-026 JUN 00 PCM - Returned Product Feedback Program
00-06-03-006 JUN 00 Settlement of Lawsuit on Batteries (CA Proposition # 65)
00-06-03-003 MAY 00 Battery - Testing and Replacement
00-06-04-021 MAY 00 EVAP System - Service of Connectors
IF this is hard to under stand go to www.Alldata.com
If they try to tell you there isn't a problem, take one of the service writers for a ride to SHOW THEM the problem.
Good luck. Hope you get it all taken care of.
