90mm NW throttle body problem, need help.
Old Apr 22, 2007 | 11:17 PM
Abdullah's Avatar
Default 90mm NW throttle body problem, need help.
the mods are in the signature. the car doesn't idle well it idles sometimes at 900-1000 rpm some times after i press the gas pedal idles at 2000rpm although i adjusted the idle screw, why? the car is not tuned yet still on the stock tune. if i tune it will this problem disappear? if i switch to LS2 TB is a good solution? tell me what is the solution for my problem.
thanks.
