AIR pump removal on 00-02's?
Old Apr 14, 2002 | 08:43 PM
badass 2002 z28's Avatar
Default AIR pump removal on 00-02's?
Seems like the newer F-bodies have this little thing that's bolted to the back of the driverside head that's part of the AIR pump. I removed mine the other day and found that there's a line that goes from that thing somewhere. I didn't see where that line mounts up and i got a vaccum leak now....Can someone please tell me if they blocked off where that line went after removing the air pump? Also where exactly is it located?
Thanks
Old Apr 14, 2002 | 10:33 PM
WILWAXU's Avatar
Default Re: AIR pump removal on 00-02's?
yeah.. saw that. I put a srew in it to plug it up. Funny.. the "tip" on top had been broken off.. looked like it had been that way for awhile.
Old Apr 15, 2002 | 12:20 AM
found it...nevermind
Old Dec 30, 2005 | 05:47 PM
FRCBobby's Avatar
Where did this line go to?? Just removed mine and saw where line was suppose to be but there was nothing there.
Also, what needs to be donw with the vacuum line righ at the air pump??
Old Dec 30, 2005 | 06:23 PM
oange ss's Avatar
its a vacuum line that tee's off the MAP/HVAC control line
Old Dec 30, 2005 | 09:06 PM
FRCBobby's Avatar
What do I need to do to it?
Cap it off or what?
Old Jan 5, 2006 | 08:21 PM
WILWAXU's Avatar
Cap it off or what?
Not sure how much you have taken off. It eventually plugs into the back of the intake, near the a/c vac & MAP sensor. If that part is left open, you'll have a vacuum leak.
Old Jan 6, 2006 | 07:54 AM
NHRATA01's Avatar
I believe it runs from the AIR distribution block on the back cylinder head to a small box near the fuel rail, which has another vacuum line presumably running to the back of hte intake, and an electrical connection. I just removed the line from the AIR distribution thing from the black box, and put a vacuum cap ($1.99 from autozone for a package of about 8 various sizes) over it to plug it.
Old Jan 6, 2006 | 09:36 AM
Zymosis's Avatar
https://ls1tech.com/forums/generation-iii-external-engine/328977-exhaust-backfires-running-rich-poor-mileage-come-air-removal.html
good pics, may help, he used a screw to plug it in the write up
Old Jan 6, 2006 | 12:33 PM
NHRATA01's Avatar
Ok seeing that write up now, I've got a question. How do you get the bracket out from the inner fender well down below that the AIR pump itself mounts to? I found the 4 bolts and removed them, but could not get it to budge. So I removed the pump from the bracket itself instead, and just left the bracket be in the AIR compartment, since I couldn't figure out what was still holding that bracket in place.
Old Jan 6, 2006 | 01:12 PM
Zymosis's Avatar
Are there 4 or 6 bolts on that thing? If I remember, maybe there are 4 bolts that face the rear, and 2 that go upward. (It has been a while since I have done it) I could be wrong (and maybe different on different years (I know 99's have a diff pump than the one on that write up)
It should come right out, when I took the bolts out, it just fell out.
Old Jan 6, 2006 | 01:52 PM
NHRATA01's Avatar
There were 4 facing up from what I could see, and what it looks like in this pic.
It looks like that's all there is, but I'll be damned if the thing didn't feel like it was bolted in elsewhere. I gave it some good yanks, enough that the bracket started to bend, and it wouldn't budge. Gave up because I was afraid of breaking something. Oh well, just an extra 1-2 lbs to lug around.
Old Jan 6, 2006 | 02:12 PM
01 Red WS6's Avatar
Take of the plastic inner fender cover and you can see better and have more room to work with. Unless you have already done that
Old Jan 6, 2006 | 02:51 PM
you2slo's Avatar
4 bolts took mine off. I also used a screw with some silicon caulk on it to seal off the vacuum line.
