x-pipe into borla?
Old Apr 17, 2002 | 09:44 PM
99blkta's Avatar
Default x-pipe into borla?
can this be done and how do you think this will sound? i was thinking of doing this since i already have the x-pipe on my car with bullet mufflers dumped, but i was thinking of replacing the bullet mufflers with pipes going out to a borla exhaust setup with muffler. will this work?
Old Apr 18, 2002 | 08:04 AM
WILWAXU's Avatar
Default Re: x-pipe into borla?
You can make anything work <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
If your talk about seperate borla mufflers.. then I don't see why not. If your running it to a single tube borla catback.. why put a x-pipe? A flowmaster collector would work better.
Old Apr 18, 2002 | 02:16 PM
99blkta's Avatar
me either, i just want to run tips all the way out!
Old Apr 19, 2002 | 12:24 AM
Black Sunshine/ 00SS's Avatar
how thick is the case on the Borla that you are thinking of? Anything over 4" & you will have some issues. I would like to replace the bullets also, but have not been able to find a reasonable one that I like that is also 4".
Old Apr 19, 2002 | 08:33 AM
ktm520's Avatar
Black Sunshine/ 00SS - have you considered flowmasters delta force muffs? they make 3" mufflers that are 3"x8"x6" for a single chamber and the 2 chambers are 12" long. i saw some pics of a guy that used them mounted right before the axle and then turn downs. they barely hung below his sfc's.
