Indexing spark plugs....
Old Apr 24, 2002 | 08:57 PM
Slow Z28's Avatar
Default Indexing spark plugs....
i know what it is....just which way do you want the plug pointing in our cars? which way do you want the tip pointing? thanks
Chris
Old Apr 24, 2002 | 11:30 PM
Brother J's Avatar
Default Re: Indexing spark plugs....
You want the tip of the outside (ground) electrode pointing down toward the piston. As long as they are within a 90 degree downward arc you will get the benefits of indexing.
Old Apr 25, 2002 | 09:28 AM
BYBYC5's Avatar
*Bad Trader*
ok i know what indexing is, but, how do you do it, it not like we got alot of room down in there to see what im doing....
Old Apr 26, 2002 | 12:46 AM
Brother J's Avatar
Wrap a piece of masking tape around the plug socket, make a mark 180 degrees opposite the tip of the outside electrode. Line the mark up so that it points upward when torqued. Trial and error.
