Using 28# injectors in a 99'
Old Apr 29, 2002 | 08:25 AM
I8COBRA's Avatar
Default Using 28# injectors in a 99'
Would I need PCM reprogramming if I swap my 26#'s with 28#'s?
Anyone do this without programming?
Thanks, Pete
Old Apr 29, 2002 | 08:36 AM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Default Re: Using 28# injectors in a 99'
If you swap injectors, you can always adjust the a/f ratio with a MAF Translator. I'd swap the injectors and get it on a dyno w/ a wideband O2 to see where the a/f ratio really sits. The O2 sensors are pretty inaccurate.
__________________
