PCV update
Old May 4, 2002 | 02:46 PM
StevieZ's Avatar
Default PCV update
Well since putting on the new PCV "fitting" , I have put 2500 miles on the car and it has not used 1 DROP of oil and the throttle body is still clean as a whistle. I don't know what it was like before since I put the fitting on right after I bought the car. Just a FYI
Old May 5, 2002 | 08:31 AM
WILWAXU's Avatar
Default Re: PCV update
You have a part number for that fitting?
Old May 5, 2002 | 10:59 AM
MY99TAWS6's Avatar
The new pcv is only part number showing now for the ls1's.I first did simple vertical pcv mod..just put valve in drivers side valve cover grommet at back and ran new tubing to front of tb.when I did cam the other day still had good oil in my tb and intake so the simple vertical mod didn't seem to help much if at all.I just put in the new valve thing so will see what that will do and also went to 10/30w amsoil synthetic from the thinner 0/30w I had been running..bonus seems to be my infamous ls1 ticking/light knocking noise even when car is warm seems to be gone or lessened greatly.
