LS6 intake question
Old May 6, 2002 | 04:37 PM
smokin' joe 00 ss's Avatar
Default Re: LS6 intake question
Yes if you are going to do a cam in the furture it's worth it, and for TX emissions I don't know
Old May 6, 2002 | 04:47 PM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Active Streak: 90 Days
You won't show much of a HP increase w/ just bolt-ons, but it will make a difference once you swap cams out. As for TX emissions, all they do for the OBDII cars is hookup to the PCM and scan for codes. If you have ANY codes stored, then you'll automatically fail. You'll have to have the EGR deleted from your PCM so that it doesn't throw a code. Otherwise you won't pass inspection.
__________________
Old May 6, 2002 | 05:21 PM
rick's Avatar
I didn't dyno my car yet with the LS6 intake, but I can tell you my car picked up some top end power judging by my trap speed gains. I still have the stock cam.
before: best of 107.5 - 108.0 mph
after: best of 109.0 - 109.5
similar weather conditions.
<small>[ May 06, 2002, 05:25 PM: Message edited by: rick ]</small>
Old May 6, 2002 | 09:52 PM
Kaji98Z's Avatar
Thanks guys.
Old May 7, 2002 | 12:35 AM
Kaji98Z's Avatar
Default LS6 intake question
Do you think I should get a LS6 intake without running a aftermarket cam? Will I pick up enough to justify the cost? I will be doing a cam in the future.
Also I want to be able to pass TX emissions so what all do I need to get?
