How do you know when its time for bigger injectors?
Old May 6, 2002 | 11:40 PM
MechMan's Avatar
Default How do you know when its time for bigger injectors?
I dont have A-tap. so when should I go to bigger injectors? Right now Im about 400 RWHP on
stock 2000 injectors.
Here is my list of mods if it helps.
LS6 intake
T1 cam
3:73's. with a 12 bolt on the way.
Grotts with O/R, prodyno cat back
ASP pullies
Lid, descreened Maf
Old May 7, 2002 | 08:55 AM
MIGHTYMOUSE's Avatar
Default Re: How do you know when its time for bigger injectors?
you will have to get onto auto tap and check for the duty cycle to be over 100%
Old May 8, 2002 | 05:36 PM
Sparky's Avatar
You and I are right at the same HP point and have the same size stock injectors. On some recent runs, I calculated my duty cycle and it was maxing at around 105% (I need bigger injectors) You want to shoot for a max DC of around 80-85%.
Don't have the formula here but search in the computer section. y2khawk posted the formula recently in a thread. You need to log your bank1 and bank2 base pulse width's and then convert them to duty cycle.
Since we're the same, I guessing you're in the same boat as me.
Mark
Old May 9, 2002 | 11:49 PM
MyLS1Hauls's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by MechMan:
<strong>I dont have A-tap. so when should I go to bigger injectors? Right now Im about 400 RWHP on
LS6 intake
T1 cam
ASP pullies
Lid, descreened Maf</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I personally think that you're ok. My buddy had a similar setup and ran stock injectors and it was fine. Shoot, it was running too rich and it was fine...2000 injectors. I forget what the injector P/W was...I've heard that 20 is a little on the high side.
Brad
