Valve cover breather?
It is not good to dissconnect your PCV system. You may actually worsen your oil consumption only now through the piston rings while also increasing blow-by oil contamination.
The vacuum in your intake manifold pulls a slight vacuum in your crank-case to help seat your rings. Ever heard of a vacuum pump? These are usually used to promote a good engine vacuum after the installation of huge cams and forced induction systems. They're also used to allow an engine builder to use lower-tension piston rings to help reduce friction (more power), while still seating the rings. W/O engine vacuum, your rings may not seat properly and you could be looking @ more oil consumption, and maybe even some leaky oil seals (ie:valve cover gaskets/front cover/ect.).
The recommendation to assist in your problem is a catch-can and perhaps the swap to an LS-6 PCV system. You may still lose oil, but it will collect in the catch-can, instead of the intake system. With this, you'll still keep the needed PCV system to keep those rings seated.
Sounds like you have something wierd going on there. Have you replaced your actual PCV valve? If this seems like a stupid question, don't take any offense. Some people just don't know that there is even such a thing on these motors...
