Pulled maf screen, need help!
is around .87 and the other is around .92, timing is around 26-29 degrees and lterms are around -4-6. Did screwing with the maf do anything? What else can Ido to get my car running right?
Any help is greatly appreciated!!
well ya i was thinkin about taking my screen out to.. but wasnt to sure that it could all good there had to be some kinda effect on the car.. looks like u found it.. sorry i don't no how to help u tho. But i think im gona leave my screen in for a bit longer till i figure out its safe or not.
5 minutes in gear (A4 only)
5 minutes in park (nuetral for M6)
Shut car off for 30 seconds. Then ATAP the car.
BTW, O2 reading aren't that good for true WOT fuel ratio readings - very inaccurate.
Good luck, let us know what happens.
Side-effects: it'll f with your idle a bit (mostly on deceleration and this I know only from M6's)
also, to prevent excess dirt in the intake and, god forbid, engine, use a good filter.
All LS1's will pick up power from this mod . . . when done correctly.
Some PCM's learn instantly . . . others not the case.
Definitely do what OBSSSD said. BTW: your O2 average is about right.
Did you monitor Knock Retard?
Parameters to be monitored: KR, First Bank O2's, timing advance, rpm's, throttle pos, L terms B1 and 2.
http://www.ls1.com/forums/showthread...5&goto=newpost
