Install on hooker headers. How was it?
Old May 9, 2002 | 02:04 PM
LIL SS's Avatar
Moderator
Default Install on hooker headers. How was it?
I'm looking at picking up some Hooker Long tube headers but want to know:
All the good and bad details of the install.
How you did the install (Rack or on stands)
How long it took
Missing parts
Time spent doing it
Thanks guys.
Old May 9, 2002 | 04:31 PM
catapolt's Avatar
Default Re: Install on hooker headers. How was it?
The installation is pretty straight forward. once the car is up high enough the headers slip right in. the hardest part is cramming the driver side o2 sensor in, it is a really tight fit. hooker should have made the 02 bung on the inside of the header. hope this helps.
Old May 9, 2002 | 05:30 PM
LIL SS's Avatar
Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by catapolt:
<strong>The installation is pretty straight forward. once the car is up high enough the headers slip right in. the hardest part is cramming the driver side o2 sensor in, it is a really tight fit. hooker should have made the 02 bung on the inside of the header. hope this helps.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">How long did it take you?
Old May 9, 2002 | 05:38 PM
Slow Z28's Avatar
after everything stock was removed, only took 1.5 hours to put in place and bolt steering stuff back up. total i can't tell you cause i did little bits here and there. and i did it by myself.
Chris
