Fuel pump power wire
Old May 14, 2002 | 11:43 PM
QWKRTNU's Avatar
Default Fuel pump power wire
Where does the wire start and end? Also where does it travel and where? Trying to add a fuel cutoff switch? thanks
Old May 15, 2002 | 02:16 PM
MIGHTYMOUSE's Avatar
Default Re: Fuel pump power wire
on mine the wire is grey and it goes from the computer harness plug all the way straight to the fuel pump + side.
if you are going fast enough to need a switch then its easiest to run a relay to get power straight from the battery, this will give you more voltage to the pump and more pump output, plus it makes for an easy new wire to put a switch between thats not engulfed in other wires and wire loom. just a thought.
-use the old grey wire to turn on the relay. not run the pump
Old May 15, 2002 | 07:48 PM
DanZ28's Avatar
Ditto what MIGHTYMOUSE said, that's what I did, All new cableing from the battery to the Walbro pump..
Dan
