Could my intake manifold gasket cause this?
Could a bad intake manifold gasket cause this?
I fill my coolant to the top of the radiator and a couple days later it has dropped a several inches. It's not my radiator cap and I have no spots on the ground where I park so I am pretty sure it's not just a leak. What are the other possible causes? Before I replace my gaskets I want to make sure I am not throwing time and money away. Also, does anyone know the gasket part numbers or where and what kind to get?
Thanks,
Matt
Thanks,
Matt
no no... check the rear coolant vent lines... the small little gaskets have a tendancy to leak, dribble down the back of the block and burn off on the bellhousing.. you wont see anything on the floor, and you loose coolant..
check those 1st.. check your front ones as well, and check the hose that is coming off of it near the intake to the radiator
Originally Posted by Blacker
Check the oil and see if any coolant has made it to the oilpan. Also, check the tailpipes for watery residue indicating coolant.
