Low RPM misfire
Old May 7, 2007 | 12:54 AM
LordOfChaos's Avatar
Default Low RPM misfire
Hey all.. i tried using the search function but it kept just sending me to google???
I have a misfire below ~1500 rpm, everywhere else its fine, even at HIGH RPM. at first i thought it was an off idle stumble, but it does it in every gear it i have it at that low of an rpm. Cruising at 60ish mph in 6th gear is apprx 1400 rpm (3.42 gears) and it will have the SES light flashing all the time, if i give it any extra throttle it feels like several cylinders are misfiring.
any ideas?
i'm thinking new coils/wires... as they are both stock.
Old May 7, 2007 | 04:13 AM
GET_SOM's Avatar
Have you modded anything recently? done anything with your ignition (coil packs, plugs, wires) or your fuel?
Old May 7, 2007 | 08:19 AM
Torque_Wrench's Avatar
Def. start checking your spark plugs and wires first.
Old May 7, 2007 | 09:23 AM
plugs are brand new
had the problem before i did the heads/cam/headers/lsx90 setup but it wasnt as obvious (still did the SES light flashng etc.)
Old May 7, 2007 | 11:18 AM
3.4camaro's Avatar
textbook ignition problem. the ignition system is at hardest work at low rpm and high load(accelerating).
do plugs and wires. then try and isolate a coil.
Old May 7, 2007 | 12:33 PM
i'm putting new wires on it tomorrow or wednesday, then will check plugs... if its still an issue i will start changin coils.
oh yea.. the code says random multiple cylinder misfire
Old May 7, 2007 | 01:00 PM
LightFighter's Avatar
prolly the wires I bet you messed them up when you changed the plugs,
Old May 7, 2007 | 01:02 PM
possible however it had the issue before i changed the plugs... the heads/cam setup seems to have pronounced the problem
Old May 7, 2007 | 01:11 PM
they pulled the wires off when the put the cam and head on so are they OEM wires?
Old May 7, 2007 | 01:14 PM
i did the head/cam swap. they are the factory wires. however they only have 28k miles on it
Old May 8, 2007 | 12:14 AM
MdFormula350's Avatar
check the ohms of the wires, should be around 300 to 500 ohm range.
the wires should click twice on the coils and just once on the plugs, but I am sure you know that already.
check the plug tips make sure they are tight, sometimes the tips that screw on get lose and might cause something like that.
also disconnect your coil pack connectors and reconnect them to make sure everything is seated and tight.
Old May 8, 2007 | 12:04 PM
onecamaro1's Avatar
I just had the same problem yesterday and i have 2 month old tr55's. I pulled them and they appear to be fouled, so i am saving them to get a better look at them. I put in new plugs and the problem is gone. I have new msd coils and msd wires.
Old May 8, 2007 | 06:49 PM
Black Sunshine/ 00SS's Avatar
Been there. Change the plugs & wires. I prefer NGK TR 55 & MSD. My problem ended up being bad coils. It looks like the enectrical connections got fouled up from my spraying the engine off @ the car wash.
Best thing is to find a friend with similar car, and switch one side of the coil packs at a time, clearing all codes after & seing if that works.
Could also be a bad 02 sensor. When it flashes on & off, that indicates a misfire. So def one of the above listed items. Good luck.
Old May 8, 2007 | 07:25 PM
KissMyWhiteSS's Avatar
I have the SAME exact problem going on...I have a post on here somewhere.
https://ls1tech.com/forums/generation-iii-external-engine/710372-i-m-lost-what-causes-these-codes-please-help-me.html
Old May 8, 2007 | 08:16 PM
02 sensors are brand new, tuner said they are fine (they have less than 200 miles on them)
this WHOLE setup has less 500 miles on it (heads/cam/headers/lsx9090/plugs)
puttin msd wires on it tonight, see what happens.
Old May 13, 2007 | 11:09 AM
Blades's Avatar
what happened?
Old May 13, 2007 | 01:47 PM
it seems to have gone away... also had my tuner reflash it.
i think the back pass side (#7 i think) wire was partially broken (wire was pulled out some)
Old May 30, 2007 | 01:13 AM
squall01's Avatar
so a bad 02 sensor can cause the flashing ses? because i just had mine changed and about that time was when the problem started.
Old May 30, 2007 | 01:19 AM
waldershrek's Avatar
So you replaced the broken wire and it went away or the tune fixed it?
