Bosch 13111
Old May 8, 2007 | 12:19 AM
SS4Luck's Avatar
Default Bosch 13111
I understand that instead of getting o2 extensions for my front o2's i can just get the 13111's... is this true? and if so i need somewhere that has them and can get them to me... soon... like as in as close to tomorrow as possible...
any help would be greatly appreciated... thanks
Old May 8, 2007 | 12:35 AM
GR33N GoblinM6's Avatar
true.. and
anywhere that sells O2 sensors
Old May 8, 2007 | 12:49 AM
Starz T/A 17's Avatar
I know advanced auto sells them, so does auto zone, pretty much anywhere that sells bosch products
Old May 8, 2007 | 10:00 AM
blacksskid07's Avatar
advance
Old May 8, 2007 | 10:53 AM
ShevrolayZ28's Avatar
I'd be more inclined to get extensions and run the stock sensors. I have not had good luck with the Bosch 13111.
Take a look at the post by Slowhawk on the last page of this thread:
https://ls1tech.com/forums/showthrea...ighlight=bosch
Old May 8, 2007 | 11:21 AM
98Camarod's Avatar
^^Same thing happened with me. I just put some stock ones in and extensions. I had idle surging and it was running rich on one bank and lean on another. Retarded bosch sensors. They are not as large as the stockers.
Old May 8, 2007 | 11:24 AM
oange ss's Avatar
open the flutes up a little before installing them...
Old May 8, 2007 | 11:30 AM
SS4Luck's Avatar
open the flutes?
as in take a screw driver and twist it a little inside the slots on the senser>?
oange ss's Avatar
exactly....
Old May 8, 2007 | 11:42 AM
MdFormula350's Avatar
autozone, ask for rear 02's for 2003 corvette zo6 they are 52 bucks each, when u get them check the box and number for the 13111 and ur good to go.
Old May 8, 2007 | 12:04 PM
SS4Luck's Avatar
i just called my autozone and they have two and im going to pick them up after school on my way to the shop
Old May 8, 2007 | 01:08 PM
98Camarod's Avatar
Hopefully it's not a waste of your time. I was one of the unlucky ones with the Bosch 13111's.
Old May 8, 2007 | 03:33 PM
FireSilverLullaby's Avatar
open the flutes?
Yeah im throwing some o2 codes, i think i might try that sounds like a good idea. i do have 60,000 miles on the stock sensors, so maybe i should just replace then.
Old May 8, 2007 | 04:17 PM
oange ss's Avatar
that procedure was researched by another member, i cant take credit for it...the stock sensor config has 5 or 6 slots, the 13111 only have 3, that's the reasoning for opening the slots, to allow more airflow to the sensing element
Old May 8, 2007 | 05:49 PM
interesting about the slots overall most people are running them in stock form with good results.
my stock 02s only had 14k on them and they looked horrible, but I am pretty sure they were working fine, but being over 6 years old, surviving gm top end cleaner and 2 seafoams i didnt want to re use them anyway.
Old May 8, 2007 | 06:29 PM
Black Sunshine/ 00SS's Avatar
I am having good luck with them so far. If you buy them, get them from NAPA, they are the only place that has a LIFETIME waranty. Change them every year if you want. No questions asked.. Good luck.
Old May 8, 2007 | 08:18 PM
SS4Luck's Avatar
i already bought them from Autozone.. there arent too many napas around here... maybne ill find a way to return the other ones and get ones from napa as they arent quite on my car
Old May 8, 2007 | 09:21 PM
ONEBADASSWS6's Avatar
I have the "slow response" code (both sides) after installing LT's, the O2's are original and have 87K on them.
I was going to replace them with Bosch 13111's....but after reading about them not working properly, would I be best off just going with the stock Bosch upstream replacements for an F-body??
Old May 9, 2007 | 06:18 PM
good tip about napa blacksunshine! im definitley gonna get them from their. but my ses light has been off for a few days again, i think the warmer weather is helping.
Old May 9, 2007 | 09:42 PM
98Camarod's Avatar
They are both the same bosch o2 sensors except the one has the long wire. They both kicked on the code for me and the shorter ones were more expensive!
