To Pulley Or Not To Pulley That Is the Q?
Much less of an issue with M6. I would also guess that, of all the driven accessories, the alternator is one of the easier ones to spin, so if you're putting an overdrive pulley on your alternator, it's probably not going to negate that much of the underdrive-pulley gains. Still worth it IMO.
I wish someone had some info on how many hp the overdrive alt. pulley takes away. Cause if it takes away 3hp then i cant see spending 200$ for 5 more hp. I wish it just added a solid 10 or 15.
Originally Posted by MeentSS02
I personally don't think it is worth it, but other people would disagree. I had some problems with charging with an aftermarket 160 amp alternator at the stock idle RPM (800).
Originally Posted by wht01ws6ta
It will also spin your water pump slower-I ran about 5 degrees hotter after installing an UDP...until I installed an electric water pump. Now I'm cool again
Originally Posted by bad6as
so has any one found a lower price on an asp unit?
They are an excellent company to do business with!
LM Performance also has them for $189.99 with free shipping. See this link: http://www.lmperformance.com/599/1.html
25% under on the crank and 15% over on the alt. you not losing anything by putting the alt pully on. def do the underdrive crank. stock pully blows *** anyway throws a belt all the time. i suggest the slp do to the highwall design.
