4" to 3" reducer
Old May 8, 2007 | 10:41 PM
01 Red WS6's Avatar
Default 4" to 3" reducer
I'm looking for a 4" to 3" exhaust reducer for my mufflex Y. I found one from Hooker but it's 4" od and it doesn't slip fit like it should. Instead it butts up to the Y pipe opening. I need a 4" id
anyone know where I can get one?
Old May 8, 2007 | 10:42 PM
Tainted's Avatar
you could always have the end of it expanded at an exhaust shop if need be
Old May 8, 2007 | 11:09 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I used a pipe expander and some southern engineering on mine. Looks liek ***, but who's looking.
Old May 9, 2007 | 02:07 AM
TheBlurLS1's Avatar
That's what she said...
You're going to have to probably weld up a slip fit reducer anyway, as a clamp there probably won't work. You can buy 4" couplers, weld one end to one pipe, let it slip over the other end, and use a clamp.
Thunder sells the 4x3 reducers.
Old May 9, 2007 | 08:34 PM
01 Red WS6's Avatar
I have the one from thunder but it doesn't fit. I have it welded up but it looks like crap and it's pretty mangled. I'm redoing the exhaust on the car so i thought I might be able to find something that actually fits correctly.
