@#$#$% Spark Plugs!
Old May 18, 2007 | 04:35 PM
SS4Luck's Avatar
Default @#$#$% Spark Plugs!
just ranting a bit.. im in the middle of a plug/wire swap and the damn passangerr side is just a pain in my ***!!!! guys wiht big hands were not ment to work on that side of the car...
Old May 18, 2007 | 04:38 PM
bww3588's Avatar
shoulda done it when you had your exhaust manifolds off doing your headers. i pulled all 8 plugs, put anti seiz on the new ones, gapped them and got them in, in 10 minutes. all from underneath.
Old May 18, 2007 | 04:46 PM
SSpdDmon's Avatar
Headers should make it easier vs. manifolds.
Old May 18, 2007 | 05:00 PM
Demon Of Dreams's Avatar
after I had done my header install... I realized that maybe I should have, after getting the headers at least up into the engine bay, installed the spark plugs and secured the boots on the plugs... reason being, it would have made my life much easier...
Old May 18, 2007 | 05:33 PM
2_wacko's Avatar
Its alot easier if you remove the coilpacks.
Old May 18, 2007 | 07:16 PM
senicalj4579's Avatar
i had to spend a few days on the treadmill before i did my plug change.
Old May 18, 2007 | 07:40 PM
realmendrivev8s's Avatar
agreed, and leave the rear bolt out when you put them back on. It took me a good 10 minutes to get that bolt off and i have small hands
Old May 18, 2007 | 09:07 PM
shooter's Avatar
+1, it's so much easier if you remove it (ditto)
Old May 18, 2007 | 09:19 PM
98Camarod's Avatar
I dont see what the big deal is about the back bolt. It's not that hard to get in there. Maybe my car is different or something, and I have pretty big hands.
Old May 19, 2007 | 03:42 AM
SS4Luck's Avatar
me and my friend didnt pull the pack... we just took the scars and wedged out hands down in there...
took us almost 4 hours tho
Old May 19, 2007 | 06:08 AM
cowboysfan's Avatar
removed coil pack and you can save 3.5 hours...... I know I got big hands!!!!
Old May 19, 2007 | 02:25 PM
Hobb3s's Avatar
I just got done doin mine yesterday. I put 3 on the passenger side and 1 on the drivers side from underneath. The only tool I can really recommend using for this is a u-joint extension
Old May 20, 2007 | 03:58 AM
SS4Luck's Avatar
whic drivers side did you put on from underneath.. all mine are really simple to get to... even with the air hooked up
Old May 20, 2007 | 12:49 PM
TonyG's Avatar
cant wait to do mine!
Old May 20, 2007 | 01:07 PM
JL ws-6's Avatar
Race your car!
it's alot easier with the emmissiosn crap gone too... once you rip all that off there's more room. drivers side gets real easy with the air gone, it helps on the passenger's side soem. taking the a/c off makes it alot easier on the passengers side... ripping the heat out completely.. makes it a walk in the park. (I have yet to take the heat out, but after seeing the room a car without heat has, mine's coming out without a doubt)
Old May 20, 2007 | 01:43 PM
redhotz28's Avatar
On the pass side i find it easier to unbolt the starter and let it sit on your chest then you have access to the last three from the back. then you can get the front one from the top.
Old May 20, 2007 | 01:49 PM
Rob98LS1's Avatar
mine has no emissions but still took me and a friend 2.5 hours to change them out! The driver side was done in 20 minutes but the passenger side.... couldn't get the damn rachet off the plug on last one, it kept hitting the firewall. Had to take 2 coil packs off too haha. I'm not changing spark plugs for 40000 miles lol.
Old May 20, 2007 | 06:07 PM
JL ws-6's Avatar
Race your car!
I take the whole coil pack tray off, 3 bolts and one big connector, and whamo lots more room.
removing heat makes twice as much room as removing the starter
Old May 21, 2007 | 01:14 AM
4U2BNVS's Avatar
Man I'm glad I don't have these problems. I got rid of emissions and have headers and I only have to change the very back one on the passenger side from the bottom and all I use is a sparkplug socket and a ratchet nothing else I can change plugs in 35 to 40 minutes tops.
Good luck with the plug change
Old May 21, 2007 | 07:55 AM
98Camarod's Avatar
Thats the same with me, but I get them all from the top with just a ratchet and spark plug socket. It's not as hard as everyone makes it out to be.
