Fake
Old May 22, 2007 | 09:55 AM
Jwahdan's Avatar
Default Fake
Does abybidy know where to get a fake catalytic converter? I want this because im trying to get an ORY but i want my car to pass emissions.
Old May 22, 2007 | 10:02 AM
MrDude_1's Avatar
thats so illegal, noone sells it.
you can either make one.... or just put good cats in your ORY....
what some people do, is take the heatshield or outer shell of the cats, and weld it over the tube.
but like i said, its illegal.
and you wont pass any sniffer test.. only a visual.. and thats just a maybe.
Old May 22, 2007 | 10:03 AM
firebird5134's Avatar
If your talking about passing emissions by visual check alot of guys just open their cats up and gut the inside. Im not really sure if there's anywhere online that will sell a fake cat
Old May 22, 2007 | 10:07 AM
sbusby's Avatar
Don't they put the sniffers on the tube to see what the levels are? And your service engine soon light will come on for "catallitic threshold failure" which, then won't pass emissions. You would then have to buy O2 Mock Sensors to fake the signal
Old May 22, 2007 | 10:08 AM
CaMaRo67RS355's Avatar
gut the stockers not too hard my buddy just did it on his ws6 for the same reason
Old May 22, 2007 | 10:24 AM
tylerdj's Avatar
either gut out the stock cats or weld the heat shields around some pipe maybe
Old May 22, 2007 | 11:47 AM
LS69TA's Avatar
You'll only pass if they do a visual check. If they put the sniffer on it, you're screwed.
Old May 22, 2007 | 02:05 PM
blownta00's Avatar
just gut the cats and get o2 sims to take care of the code
Old May 22, 2007 | 02:43 PM
black01_WS6's Avatar
cut some cats in half then weld them around your pipes, or gut them. Where state do you live in?
Old May 22, 2007 | 06:18 PM
INMY01TA's Avatar
What state do you actually need cats to pass emissions in? (besides Cali)
Old May 22, 2007 | 07:45 PM
jond99's Avatar
Tell me about it. In Ct they just plug and play on your comp. for a min and send you on your way.
Old May 22, 2007 | 07:46 PM
kistlerjm9's Avatar
pa has to have them. but for obII we just have to have a visual and pass a diagnostic test AKA no codes so we do need o2 sims. pass mine all the time with "no cats"
Old May 22, 2007 | 08:14 PM
Jwahdan's Avatar
Default Virginia
I live in Virginia, and im not sure if its required for emissions but my friend said it was so im trying to figure out a way to get away with it.
Old May 22, 2007 | 08:55 PM
Boodyrider's Avatar
OBD1: sniffer
OBD2: plug n play
OBD1, may pass, but tune will have to be optimized for emissions, not power, and may need some alcohol in the tank to pass. Note that a big cam is gonna be a BEAR to pass in an OBD1 car with no cat. Another method that works in states that use a dyno for the sniffer test is to lower the car so far it would be damaged putting it on the rollers. In Maryland they give a waiver in that case.
With OBD2, O2 sims or (preferred) modifying the tune to prevent codes and Check engine light. Almost any cam can be made to technically pass without throwing codes this way... and MOST emissions places will ignore the obvious sound of a modified engine.
Regardless, cats should not just be gutted if performance matters to you, as the turbulence will rob a significant amount of power. You'll need a 'test pipe' welded inside the 'cat' to keep flow happy.. and NO legitimate exhust shop will do this, as the fines are amazing for a shop. (Performance shops, now, will and do do 'off road only' modifications for the 'race only' customer cars.)
