removing washer fluid tank?
Old May 26, 2007 | 05:36 PM
cals400ex's Avatar
Default removing washer fluid tank?
i was thinking about removing the washer fluid tank to remove a little extra weight. plus, this might allow me to rig up a little better ram air from underneath the car. i just wasn't sure if there was any way i could get around the light in the guage cluster for the tank to be missing?
Old May 26, 2007 | 05:46 PM
Tainted's Avatar
just keep it. you gotta cut up and mvoe a lot more stuff than jsut the washer tank to do the big gulp ram air or the other one similar to it
Old May 26, 2007 | 05:55 PM
outkast6991's Avatar
i took mine out and do not have a light lit. i just unplugged it and threw it away . i did it for a sux2bu ram air setup that has been very good to me
Old May 26, 2007 | 07:07 PM
Krab's Avatar
You will not have any light go off in your instrument panel, just drain it, disconnect the plug and fluid line and remove it from underneath the car. Be sure to plug up the fluid line so it won't get any debris in there just in case you plan to put the reservoir back in the future.
Old May 27, 2007 | 01:52 PM
cals400ex's Avatar
sounds good. i am not too concerned with the ram air. that was just more of an idea. i drive this car like a few hundred miles a year or so and it wont' see a cloudy day. i have no need for the washer tank and i wanted to clean up the engine bay. does this thing have to come out of the bottom or can it come out of the top of the car?
Old May 27, 2007 | 02:34 PM
it must come out the bottom but it is no big deal. a couple plastic clips and it comes right out
Old May 27, 2007 | 03:46 PM
Ripper415's Avatar
but then what are you gonna do when you're driving down a dirt road offroading and you need to clean up your windshield???
Old May 27, 2007 | 04:47 PM
exactly what i do all winter.............curse like a sailor and wish i hadn't taken it out
Old May 27, 2007 | 05:53 PM
cals400ex's Avatar
i will put it in 4 wheel drive and go have some fun
