View Poll Results: What Intake Do You Like Best?
BBK SSI
4
2.80%
FAST 90mm
68
47.55%
FAST 78mm
3
2.10%
Weiand Ligenfelter
5
3.50%
Stock LS6
58
40.56%
Holley LS1 Intake
1
0.70%
Other (state which one)
4
2.80%
Voters: 143. You may not vote on this poll
Intake Poll
Old May 29, 2007 | 07:01 PM
5_02ls1's Avatar
i used the wieand with a ported tb its the same design as the ls6
and i dont have to worry about it blowing apart if an n20 backfire happens..you can see it in my sig...i got it new with all gaskets and new arp intake bolts shipped to my door for 420 bucks....
Old May 29, 2007 | 07:03 PM
5_02ls1's Avatar
oh yeah the holley and wieand are the same manifold you may wanna fix that
Old May 29, 2007 | 07:11 PM
5_02ls1's Avatar
https://ls1tech.com/forums/showpost....82&postcount=4
Old May 29, 2007 | 11:20 PM
FU_I_AM_UltraZ's Avatar
Veteran: Marine Corps
me having a stock motor and an 02 LS6 equiped, i like it better. best bang for the buck i guess cuase it was FREE!!!! and i guess you can always port it too...
Old May 30, 2007 | 01:18 AM
00Formula00's Avatar
Right on guys... I just picked up a LS6 intake from a buddy for $175, thought I couldn't go wrong...Im planning to go with the TR 224/224 112lsa and AFR 205's So if i need more air down the road I'll switch to the FAST 90...
How's that sound?
Old May 30, 2007 | 02:05 AM
Benjamin Russick's Avatar
Never heard of anyone having much luck porting a LS6 intake...
I currently have the LS6/portedTB combo and it is definitely costing me above 6000rpm on my 383. I just hate to pony up the $1300 for the ported FAST 90 combo...
Old May 31, 2007 | 01:05 AM
Benjamin, what do you mean costing you above 6 g's? Can you really feel the engine struggling for air??
Old May 31, 2007 | 04:40 AM
Yah. You can see the dyno curve start to flatten out and peak early. You don't "feel" it per se, but I know that I could gain an easy 20rwhp with a less restrictive intake set-up. The problem then becomes the rest of the intake tract. Bigger lid opening, bigger coupling, possibly bigger MAF, etc... There doesn't seem to be a easy (or cheap!) solution.
 Michael S. Palmer
Old May 31, 2007 | 10:27 AM
Detoxx03's Avatar
I have the ls6 intake cause thats what came on the car. I've tossed around the idea of getting the fast 90/90 once I decide what heads i'm going with. The ls6 is pretty stout though but eventually i'll go for more power and have to part ways with it.
Old May 31, 2007 | 10:54 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
I'm in the same boat as well. I currently have a stock ls6 intake and stock throttle body and put down 425/400 with heads, TR224 and QTP long tubes. I go back and forth with spending the $100 to have the throttle body ported and polished to get 7-10hp or drop the $1100-1300 for a ported fast 90/90 combo and gain 25-30hp as well as 15-20 ft/lbs of torque.
I'm saving some pennies and maybe this fall I'll spring for the FAST 90/90 combo and be sitting at 450-460hp which should keep me happy for a few more years till I decide to upgrade to a bigger cube motor, which the intake would be a great up front investment for.
Old May 31, 2007 | 05:52 PM
King Nothing's Avatar
have you checked out TPIS???????? they'll take a LS6 manifold and port it to 90mm for $400 i think . . . so a FAST isn't that needed unless your running N20. they also have dyno charts on there. always something to check out! i just picked my LS6 up off ebay for $355 . . . . check out the appearance section in acouple weeks to see it
Old May 31, 2007 | 05:53 PM
  #32
GOGO's Avatar
Save your money an do it right the first time. This way you will not be searching for a few lost ponies here and there. Get a Mamo ported Fast 90.
Old May 31, 2007 | 07:05 PM
  #33
that's why i said i guess. if you really want something and want Y but only have X and can't afford Y, you'll find a way to make and X into a Y.
Old May 31, 2007 | 07:07 PM
  #34
How's that sound?
Hell no!!! no wrong there. that's a good price. I remember after one of the GM or camaro magazines came out with an article that said about 01&02 LS1 equiped cars had an LS6 manifold on from the factory, ebay blew up and you couldn't get an LS6 manifold for less than $300 lol.
Old May 31, 2007 | 08:02 PM
  #35
i picked up mine for $380 on ebay, came off a 02 Z06, and it looks different than you normal LS6 manifold . . . . pics soon!!!
Old Jun 1, 2007 | 06:34 AM
  #36
UNDER PRESSURE MOD
Hmmmm, I wonder what the difference would be with a 90mm TPiS LS6 intake vs. the FAST intake. Now I'm really confused and tempted.
Old Jun 1, 2007 | 06:52 AM
  #37
Thule's Avatar
FAST90/90 combo here, awesome!!
Old Jun 1, 2007 | 07:54 AM
  #38
LS1-450's Avatar
Hey Guys,
I'm just trying to get a good sense of what everyone is running, I am planning on AFR 205's and a TR 224/224 112lsa...
Also with picking your intake put whether or not you ported....
And how you like it...
Thanks
Weiand here; ported to 83mm. Want to go to 90mm. Kinda run out of material near the top of the intake. If we can get it to a machine shop, can probably be done. Runners are also port matched.
Old Jun 1, 2007 | 05:02 PM
  #39
i'm waitin to here back from them about shippin my manifold to them to have it ported . . . but there's a guy here in cali that will port my LS6 manifold when i get it and port my TB i'll post dyno numbers up as soon as i get a tune
Old Jun 1, 2007 | 08:45 PM
  #40
hey alchemist, who in cali is porting your LS6?
