LS1 to LS6 PCV conversion
Old May 29, 2007 | 12:33 PM
Xtnct00WS6's Avatar
Default LS1 to LS6 PCV conversion
I have an LS1 intake, so will I be okay with the LS1 coolant vent tubes when I switch to the LS6 PCV?
I know..I know...I need to get an LS6 Intake
Thanks!
Old May 29, 2007 | 12:56 PM
SIC LSX's Avatar
no it will not work unless to grind down the bottom of the ls6 intake! but its cheep just to buy the 01-02 coolant block off's and front cross over pipe!
Old May 29, 2007 | 12:57 PM
SIC LSX's Avatar
whoops!
As far as the ls6 valley cover you should be ok you might have to push down on the coolant tube a little
Old May 29, 2007 | 02:23 PM
98C5LS2's Avatar
Thanks!
PM sent
Old May 29, 2007 | 03:27 PM
Xtnct00WS6's Avatar
Can anyone else confirm that a LS1 intake, LS6 PCV, and LS1 coolant vent tubes will all fit?
Old May 29, 2007 | 10:57 PM
WILWAXU's Avatar
Sould work fine. If you switch to a LS6 intake, then you will need the different coolant tubes.
Old May 29, 2007 | 11:01 PM
Xtnct00WS6's Avatar
I could also grind the bottom of the intake right?
Old Jun 2, 2007 | 02:22 PM
Jz Canada's Avatar
Yes, that'll work as well. I did that with my ls6 intake on my ls1 block. Just grinded out a path on the bottom of the intake manifold for the coolant pipes. But be careful.
Old Jun 2, 2007 | 02:28 PM
Tainted's Avatar
just cuz I knew you'd ask for it
Old Jun 21, 2007 | 10:08 AM
Xtnct00WS6's Avatar
Haha...thanks! That's the LS6 intake right?
I'm finally getting around to putting everything back on my engine and the LS1 coolant tube doesn't exactly fit like a glove with the LS6 PCV. The tube wants to go right over the PCV vent tube. I'm thinking I'll just cut it and use fuel lines to tie it back together. Has anyone done this before?
