WTF!! Header primary blocking oil plug
Old May 30, 2007 | 08:28 AM
ws6on19s's Avatar
Default WTF!! Header primary blocking oil plug
I've had dynatecs on the car for a few years now but only put about 1500 miles on it since, I just went to change the oil after break in of the new motor and realized that one of the primary tubes almost hits the oil plug not allowing me to drain the oil....does anyone have any tricks besides loosening the header or pulling the oil out with a manual pump???
Old May 30, 2007 | 08:53 AM
lastcall190's Avatar
I have never heard of that Dunno what to tell you man, no offense, but did you notice this when you installed them?
-J
Old May 30, 2007 | 09:02 AM
thecorrectformula's Avatar
If you are able to get it out at all you can take a piece of cardboard to keep the oil from splashing onto your headers. I cant think of any thing at the moment to help you out on getting the plug out besides loosening the bolts like you said, but after you do get the plug bolt out you can take it and grind the length of the bolt down a small amount that way you don't have to back it out so far to remove it.
Good luck with it and let me know how you did it cause I'm about to install a set of LT's.
Old May 30, 2007 | 09:09 AM
ws6on19s's Avatar
I didnt install them first time around, it was at my friends shop for rear and he threw them on while waiting for parts...when I did the motor I installed that side from the top but i guess i over looked that
Old May 30, 2007 | 09:14 AM
If you don't mind me Highjacking for a second, how much of a pain in the *** and how long did it take to install the headers?
Old May 30, 2007 | 09:19 AM
ws6on19s's Avatar
i already had the coilpacks off and it took about an hour and a half....its alot easier with the packs off..the pass side has one bolt in the back that sucks..the driver header should go through the top and the pass has to go from bottom well i know dynatecs do
Old May 30, 2007 | 09:36 AM
thanks for the info. Hopefully I can get mine on with ease.
