AFS 97 and 98..whats the difference.
Old Jun 19, 2007 | 03:08 PM
sandro arellano's Avatar
Default AFS 97 and 98..whats the difference.
Not sure if this is in the right section but i just wanted to know what the difference is between the two sensors....is the afs98 wire just longer? i ask because i need two pre cat sensors and i can get the afs97 pertty cheap...but just not sure if the sensor will work the same for both sides.
thanks for any help,
sandro
Old Jun 20, 2007 | 05:39 PM
anyone?
Old Jun 20, 2007 | 06:55 PM
BLKWS6's Avatar
the 97 is the pre converter sensor on the pass side. the 98 is the drivers. but if i remember correctly...you can use 2 97s....
Old Jun 20, 2007 | 08:00 PM
Dmoney's Avatar
Yes, one is longer than the other. They'll both work for either side...............
