miscelaneous header questions
Old Jun 25, 2007 | 11:02 PM
cenTX-LS1's Avatar
Default miscelaneous header questions
1) What bolts require anti seize?
2) Do the o2's need anti seize?
3) Does anyone have pictures/suggestions as to how on earth im going to get the car 22" in the air safely (and as cheaply as possible)? I currently have a standard jack that will get the car up in the air 13" and 2 ton basic jack stands that will go maybe 18". I know im going to have to use some lumber in there somewhere for extra height.
4) My car is an 02 with 30k on the clock. Am I ok to resuse my stock header gaskets?
Old Jun 26, 2007 | 08:50 PM
cenTX-LS1's Avatar
to the top
Old Jun 26, 2007 | 10:19 PM
black2002ws6's Avatar
What kind of headers you putting on? I only had to jack my car up around 16" off the ground to put mine on.
Old Jun 26, 2007 | 10:22 PM
motoo344's Avatar
Ya, I didnt have my car up that high, probably 16-18 inches. I put some blocks of wood on the jack for a little extra height. Headers might take some work to get in though.
Old Jun 26, 2007 | 11:06 PM
cenTX-LS1's Avatar
ARH headers 1 3/4
cenTX-LS1's Avatar
What about reusing header gaskets?
Old Jun 26, 2007 | 11:20 PM
Starz T/A 17's Avatar
reuse the stock GM ones
Old Jun 27, 2007 | 12:04 AM
tylerdj's Avatar
Yours should be fine with that low of mileage on them.
Old Jun 27, 2007 | 03:07 AM
bww3588's Avatar
i had a lift to put mine on, so i cant help you there, but i didnt use antiseize on my bolts or O2's. my bolts never came loose either. i got back under there and tightned them about a week after i put them on and that was it. i checked them yesterday and they were fine. i dont plan on messing with them till i get to school and make my custom stainless headers.
Old Jun 27, 2007 | 03:25 PM
You should always us antiseize on the bolts your putting steel bolts into an alum. head. You won't know you have a problem until you go to remove them and they won't come out.
Old Jun 27, 2007 | 03:30 PM
bww3588's Avatar
do they come with antiseize from the factory? cause i had a helluva time getting the stock ones out.
