High idle problem after motor mount install
At first I was really happy that the one mount was able to cure my y-pipe ills, but I've noticed that my car doesn't idle the same anymore. It used to idle at 700 flat, no surges. Now it varies, but will start at 1100-1200 and the slowly come down. Once it gets to around 600 it will come up and float between 650 and 750. A tap of the throttle will send it back to over 1000 and then it will come down again.
I looked for a vac leak but couldn't find one. Is there anything else that the shop could have bumped or unhooked that would cause this? It was too hot to check, but would an unhooked O2 sensor act like that, or perhaps he plugged it into the unused rear plug?
My mods are lid, K&N, P&P TB, LS6 intake, longtubes, ORY, !EGR, !AIR
1999 Z28 M6
Anywho, I double checked the vac lines in the back and they both looked good, as did the PCV lines. I need to double check my catch can, but I didn't hear it earlier when I looked. Are there any other vac lines it could be or should I start looking elsewhere. It really feels like a vac leak, I just can't seem to find it.
They did indeed. I was thinking the PCM had to be reset for that to happen, but given the fact that I can't find a leak, perhaps that's what it is. It didn't do it today on startup or on the way home, so perhaps this was a false alarm.
