wiring question need help asap!!!
Old Jul 3, 2007 | 11:47 AM
Emoney97ss's Avatar
Default wiring question need help asap!!!
There are two big black wires down by the starter... i believe they are both ground wires, but i don't think they both go to the back of the starter or do they? i know 1 should ground to the starter, but i'm not sure where the other one goes...
Old Jul 3, 2007 | 12:15 PM
DirtyJohn's Avatar
Should be one big red and one smaller black on the starter.
Unless the battery cabling assembly wasn't replaced with a stock replacement.
Most stock batteries explode and need cleanup of that whole area, I can see it having been replaced with a black wire.
Old Jul 3, 2007 | 12:21 PM
Emoney97ss's Avatar
its surely not a red wire... there are two thick black ones...
Old Jul 3, 2007 | 01:49 PM
DirtyJohn's Avatar
Does it go directly to the starter?
I really only know of 4 or so wires in that area...
- Starter hot wire typically red.
- Starter ground
- O2 wire bundle
- Oil level sensor bundle
Not sure what another thick black one would be.
