Just got headers on, not runnin right
Old Jul 2, 2007 | 03:26 PM
Snigga's Avatar
Default Just got headers on, not runnin right
Got my headers on and she's ready to go. I took her for a drive and it was fine for the first minute or so. Then I was sitting idle for a few more minutes and the whole car started shaking terribly. When I started giving it gas (as I started moving) it got better, but a few seconds later it started bogging down real bad. To just drive normally, I had to give it half throttle. Every few seconds it was like something "clicked" on and I started to take off (like normal 1/2 throttle). Then it would bog down again.
I checked the plugs and wires thinking it was misfiring or I burnt up a wire, but they were fine. Is it running lean or what? It's an 02 LS1 A4, the headers are pacesetter LTs with the ORY. No other mods.
Old Jul 2, 2007 | 03:52 PM
5.3LJimmy's Avatar
do you have your oxygen sensors unplugged?
Old Jul 2, 2007 | 03:55 PM
trans99am's Avatar
might also be a bad ground
Old Jul 2, 2007 | 04:04 PM
l337_haxs's Avatar
Thats what my first thought was
Also trans99am I would resize that sig before the mods get at it man!
Old Jul 2, 2007 | 04:42 PM
tylerdj's Avatar
Did you extend your front O2's to the bungs on the headers and put sims on your back O2's? It sounds like you didn't do one of those.
And trans99am...resize your ghetto sig
Old Jul 2, 2007 | 04:59 PM
staringback05's Avatar
number 3 for resizing the damn sig .....******* 650x450....
okie dokie....did you make sure your front o2 wires werent on/near the block or collector?
Old Jul 2, 2007 | 05:39 PM
1cleanbird's Avatar
plug in the front o2's. You can leave the rear's unplugged, but with an SES light.
Old Jul 2, 2007 | 05:41 PM
jetlag's Avatar
Did you crack a spark plug when installing the headers?
I did that.
EDIT: N/M, I reread your post..you said you checked them.
Old Jul 2, 2007 | 05:53 PM
mglooper's Avatar
I'd say check o2's if its not those I'm not sure. it definitely sounds like a computer thing not an actual malfunction of any parts or anything
Old Jul 2, 2007 | 06:33 PM
SSDriver's Avatar
if it ran fine at first I would say you melted the wires for the 02's. check and make sure the wires arnt touching the headers.
Old Jul 2, 2007 | 07:39 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
you change your sig and avatar more than i change my underwear.
Old Jul 3, 2007 | 12:42 AM
Snigga's Avatar
The O2s were plugged in. I took the rear ones out though. After I drove it a bit more, it started running nice and smooth. I put 50 miles on it to be sure and it has run flawlessly since I posted this. Is it possible the sensors just had to calibrate to the new setup? I have no issues with it at all now. Thanks for the help everyone.
Old Jul 3, 2007 | 01:19 AM
Almostryan3's Avatar
Yeah some people have that same problem...
Old Jul 3, 2007 | 08:45 AM
BREWS02WS6's Avatar
Mine started shaking and "loping" like it was cam'd...installer forgot to plug in one of the coil packs lol.
Old Jul 3, 2007 | 10:05 AM
Arctic2002ss's Avatar
Make sure that the O2 wires are not too close to the headers. I had that problem.
Old Jul 3, 2007 | 11:30 AM
Snigga's Avatar
Well, it started doing it again today. Seems if I sit idle for more than 5 minutes or so, it starts it up again. Someone mentioned something about O2 simulators. What are they? Where do I get them? And is it something that would fix this problem?
Old Jul 3, 2007 | 11:44 AM
tylerdj's Avatar
You have to have your REAR O2's either tuned out or install sims on them.
Link to O2 sims
It sounds like its an O2 problem
Also, in you haven't yet read through the sticky at the top of the page
STICKY
Old Jul 3, 2007 | 11:47 AM
Weezzer's Avatar
Rear O2's have no effect on engine performance.
Old Jul 3, 2007 | 12:40 PM
5.3LJimmy's Avatar
If it only does it after idling for a while it may be temperature related, b/c the engine will run hotter sitting still. Maybe you damaged the coolant temperature sensor or the wires to it. It is located close to the front of the header flange on the side of the head, and could easily be damaged. If it's messed up it will affect air fuel ratio at part throttle causing the engine to bog or stumble.
Old Jul 3, 2007 | 02:03 PM
Snigga's Avatar
I tuned out the rears. Also checked the fuel tables, the front passenger O2 is dead. Bought a new one, problem solved. Thanks guys.
