@#^& BROKEN HEADER BOLT
Old Jul 7, 2007 | 03:45 PM
SS4Luck's Avatar
Default @#^& BROKEN HEADER BOLT
http://i153.photobucket.com/albums/s...lass2007-1.jpg
wtf should i do? i cant really get vice grips down in there to get a good grip.... i need help
Old Jul 7, 2007 | 03:58 PM
Soul TKR's Avatar
if you can fit a dremel in there you can slice a flat slit into the top of it and then get a small flat head screwdriver and possibly unscrew it out that way...
Old Jul 7, 2007 | 04:01 PM
crazykid's Avatar
Restricted User
Grab it with some vise grips or a set of knipex pliers
Old Jul 7, 2007 | 04:15 PM
1FSTLS1's Avatar
How did that happen so I am sure I dont do that. If you loosen the motor bolts and jack the motor up a few inches would that help? How about a Maketia 90* screw gun and drill it out and use a screw extractor?? Good luck
Old Jul 7, 2007 | 04:19 PM
98Camarod's Avatar
Vice grips or slot it.
Old Jul 7, 2007 | 04:58 PM
01CaMMMaro's Avatar
he said he cant get vice grips on it!!! do the dremel way like soul tkr said or grind it flat on 2 sides and grab it with some pliers. if you cant grab it... gonna have to drop the engine or jack it up till you can... loosen those crossmember bolts but dont take them out just so you can jack it up high enough.
Old Jul 7, 2007 | 05:29 PM
WhiteStripes's Avatar
I'm guessing an angle drill with an Easy-out is out of the question? That's what I had to use when a rocker arm bolt snapped off in the head on me(and let me tell you that was a scary experience).
Old Jul 7, 2007 | 06:59 PM
SS4Luck's Avatar
well one of my neighbors is a pretty hardcore mechanic, and he came over with tiiiny vice grips and we could do ****... it was in there like the captain of the football team on prom night.... so i was in a real shitty mood. my dad came home and i told him what happened and no **** he reacher in with his fingers and turned that bitch out by hand....
Old Jul 7, 2007 | 09:16 PM
01CaMMMaro's Avatar
yay for dad!!!
Old Jul 7, 2007 | 09:24 PM
01FormulaTA's Avatar
lol @ dad to the rescue!!!
Old Jul 7, 2007 | 10:38 PM
Da Swami's Avatar
DAYUM that's some strength!
Old Jul 8, 2007 | 12:19 PM
3.4camaro's Avatar
lol i would have put some locktight on it and ask dad for some new heads
Old Jul 8, 2007 | 02:02 PM
98Camarod's Avatar
There is plenty of room for some vice grips, look at the picture, it would have just taken a while. Glad to hear you got it out.
Old Jul 9, 2007 | 12:59 AM
SS4Luck's Avatar
haha dad just bought me a new puppy, college tuition, and apartment rent, i woulda asked for new heads and he would have told e to
SS4Luck's Avatar
owned by the double post
Old Jul 9, 2007 | 01:43 AM
daniel6718's Avatar
damn..i just left my broken bolt in there...i drilled it tap broke off inside it so i said furk it...intake manifold bolt is broken off in the same head...that was fun...cant even get a tap small enough...i slotted it and used a screwdriver and one side broke off...so i left that in there too...
Old Jul 9, 2007 | 08:24 AM
RacerScott's Avatar
man....time for new heads.
