What is the size of this bolt?
Old Jul 11, 2007 | 11:30 AM
ecuxc's Avatar
Default What is the size of this bolt?
Hey Guys,
I just ordered a PCV catch can and would like to know the size of the bolt that attaches the catch can to the heads. Attached is a pic with the bolt circled. I am going to run up to Lowe's but didn't want to go through the process of trial and error.
Thanks!
Old Jul 11, 2007 | 01:02 PM
DirtyJohn's Avatar
I think its somewhere btwn 13~16mm but I can't remember for sure.
I know I had bolts left over from misc part replacements Ive done that fit, so look through your extra bolts for one that might fit and bring it to the size finder at the hardware store.
You can always test thread it into the hole on the head since its so easy to get to.
I'd also wait till you get your can before you buy it though so you know how long you need it.
I remember mine needed to be longer than I would have thought to mount right, and I needed some washers for spacers.
Old Jul 11, 2007 | 01:05 PM
bczee's Avatar
I beleive that it would be 8x1.5 mm (if that is wrong, it will be 10x1.5mm) thread size.. Head size could be anything as DirtyJohn stated.
Old Jul 11, 2007 | 01:09 PM
Mia's Avatar
Mia
Originally Posted by ecuxc
Hey Guys,
Thanks!
who makes the can in the pic?
Old Jul 11, 2007 | 02:13 PM
XtinctZ28's Avatar
Rehab is for quitters...
Mike Norris Motorsports (Sponsor) Here is a link to their GenII Catch Can: https://ls1tech.com/forums/generation-iii-external-engine/720131-mike-norris-motorsports-genii-pcv-catch-can.html
Old Jul 11, 2007 | 02:46 PM
ecuxc's Avatar
Thanks for the replies. I figured out the thread size. It is 7/16". I went for the trial and error approach at Lowe's. The length is around 1/2" but might be a little bit longer.
Old Jul 11, 2007 | 05:09 PM
bww3588's Avatar
just an FYI, its going to be metric. unless someone tapped the hole out again for 7/16's.
