What is the best Longtube for LS1??
thanks
Are you looking for budget, or gains
bottom line,,,this question needs to be answered.
There are cheaper headers,,but they are not making up the gains as some of the other "more expensive" headers out there,,and by that i mean a hundred to a few hundred more,,thats why you need to know if fyou are shopping for budget, or gains
do a lot of reading,,and dont just take one guys word,,even if they have 4000 some posts on here,,,,trust me.
If you are just wanting headers to say "ive got headers" then there are some nice Stainless Steel ones around for cheap,,,,,be sure to check out the Y pipe as most are very disruptive to flow. Some people will tell you that flow is not important, or that merge quality is of no importance,,,,,,be aware.
what ever you go with make sure there coated.
Got the off road headers and y-pipe for 504 dollars to my door from www.neweraperformance.com
https://ls1tech.com/forums/showthrea...=729219&page=2
This was for my second set of headers for my '98 T/A. First set were FLP's - they don't make them anymore and they are not near the quality and fitment of what is available now. I always had issue with trying to get them to be leak free, issues with the y-pipe banging, the ceramic coating coming off, etc. so I definately recommend stainless, screw the ceramic-coated IMO.
So I got and installed recntly the ARH, and i gotta tell ya, the are TOP QUALITY headers.
Answers to the usual questions:
Fitment: all fit together nice and tight, etc.
Finish: not a shiney as some of the SS headers, but they can be polished up if desired. personally I don't care, I just like the fact that they will not ever rust. Mine aint no show car.
Ease of installation: Are you kidding me? These were SO much easier than my old FLP's were! For comparison, to install the FLP's, I had to get the car WAY up high, then they were a pain in the *** to get them to go up onto the engine, i had to remove the oil filter on drvr side too..a bitch all in all. On the ARH, I put the car up on 18" jackstands, and both headers slid right in right on up to the motor so easy i could not believe. Nothing had to be removed or altered to get them to fit at all.
Ground clearance: I don't think it could be better. these tuck up nicely under the car, and the only clearence i might have lost was maybe 1/2" from the y-pipe to the ground, when comparing to the stock y-pipe. That is because, well hell it is a 3" diameter Y, so it's gonna have less than stock clearance, it aint much tho, the Y pipe is sorta flattened in the usual "problem" areas, so as to maximize clearance to the ground while NOT banging on the floorboard of the car. A lot of the headers out there including my old FLP have that problem of banging, and it sucks. My car is lowered about 1 & 1\4" with Sam Strano springs, and i have had no problems with clearence, except ridiculous-sized speed bumps may have scraped barely once or twice, normal speed bumps are never an issue.
So there you have my vote, the ARH !
How is the fitment on those? Also any clearance issues? How low to the ground do they hang? Are you on stock suspension? If not how "dropped" are you?
I do believe the homeowners association will make a new rule because of this car .....lol I can;t wait
I put in a bump stop on the y-pipe that seems to hold everything a lot tighter to the car.
