PCV grommet, Where to get one? pic inside
Old Jul 11, 2007 | 06:09 PM
LS1DER's Avatar
Default PCV grommet, Where to get one? pic inside
I was changing my pcv valve for the first time in a long time and noticed the inside of the grommet was disintegrating. It's almost all the way through. The dealer wants me to buy the whole tubing system for $120. Napa and advance didn't have it either. Am I stuck with looking at junk yards?
Old Jul 11, 2007 | 10:45 PM
JBsZ06's Avatar
I'm checking in to see what information you get.
I feel the plastic bucket that holds the pcv valve is allowing unmetered air into the motor.
Some guys think the oil is the issue but I tend to think its the black plastic bucket on my ls6 thats letting the air in as the pcv valve I believe is moving in the bucket ..(getting sucked in a bit and then allowing unmetered air in)
I could be wrong so I don't want to spend 180 bucks for a new one from the dealer..
I've read someone went with a twin nipple pcv valve here and regular hoses to connect..
Maybe he'll check in here..
Old Jul 12, 2007 | 02:32 AM
whs's Avatar
whs
Originally Posted by JBsZ06
I feel the plastic bucket that holds the pcv valve is allowing unmetered air into the motor...
When I changed the PCV it was like that and sucking air causing it to run lean. I ended up fabricating a new one out of some hose. No problems since, can't remember exactly how I did it (3 years ago just after buying the car). I do remember buying the parts at Autozone and spending less than $15 for them.
Old Jul 12, 2007 | 08:13 AM
JBsZ06's Avatar
Will,
If you get a chance take a photo of it. How did you get the hose to wrap the pcv valve without the GM bucket? and still mate to the ls6 hard plastic tube? or did you change pcv valve so that you had two nipples on the pcv ..?
IF so which pcv valve would you use?
Thanks
Old Jul 12, 2007 | 08:29 AM
Bad Blue WS6's Avatar
120.00? OMG! Sometimes,,I really hate dealerships,,,unless you know someone,,you get fukin monkey raped.
Old Jul 12, 2007 | 10:20 AM
MeentSS02's Avatar
Kleeborp the Moderator™
My rubber housing for the PCV valve was doing the same thing...if you go look at Vato Zone though, you'll see that they carry at least one PCV valve that accepts hose on both ends. I just bought that, and bought some 5/16" fuel line to hook it up from the outlet to the valve and from the valve to the manifold. It'll save you some money, and it is still a PCV valve (which is nothing more than a check valve anyways).
Old Jul 12, 2007 | 03:14 PM
black01_WS6's Avatar
Yup did the same thing, and works great.
Old Jul 12, 2007 | 05:39 PM
LS1DER's Avatar
Didn't even think of getting one with nipples on both ends. That's what I'll do. Thanks guys
Old Jul 12, 2007 | 07:15 PM
silent1's Avatar
[QUOTE=MeentSS02]...if you go look at Vato Zone though, [QUOTE]
That's hilarious, never heard anyone call it that............wait a second, why you making fun of my people?
Old Jul 12, 2007 | 08:32 PM
JBsZ06's Avatar
I went to a small autozone by me and couldn't find one..The place was a mess and missing quite a few pcv valves as far as I could tell looking at the rack.
Any chance when you go to the store you could get the part number and post it up here so I can order the part.
Thanks in advance. I really believe this will be a wide spread mod once the guys hear about this.
I'm not sure why one gentleman went with the 5/16's over the 3/8ths hose but if it works...Thats good enough for me.
Thanks again guys for the heads up.
Looking forward to getting the stock number of the pcv valve chosen.
JB
Old Jul 12, 2007 | 09:58 PM
MeentSS02's Avatar
Yes...I guess I am It's okay though...you could call the Cracker Barrel the Cracka Barrel, but I don't really like to eat there anyways
Old Jul 13, 2007 | 01:03 PM
89Formulaws6's Avatar
i used fuel injection hose since i just had some laying around, i think it was 5'16th too it was very simple to do
i like calling burger king the BK lounge lol if you know dane cook you'll know
Old Jul 16, 2007 | 01:38 PM
JBsZ06's Avatar
Any word on which part number from autozone or should I just try pep boys?
The local autozone pcv wall setup looks like it was ravaged by a terrorist.
TIA.
JB
Old Jul 16, 2007 | 01:44 PM
99NMB's Avatar
TIA.
JB
damn towlhead autozone workers... well we are on this subject my car has a hole in the little y thingy on the pvc system behind the intake, anyone know where i can get one
Old Jul 18, 2007 | 02:46 PM
JBsZ06's Avatar
I went to another autozone and the pcv valve they had with two nipples ...
One side is identical to what we have and the other side really requires a slighly bigger hose because the hose won't fully go on the nipple.
Did you guys just put the hose on the larger nipple partway or did you do something to get the 3/8 inch hose on the nipple.
Spray oil to lubricate it to get it all the way on?
Or did you find a pcv valve with the same size nipple on both sides?
Did you use a larger hose on one side with a reducer and a smaller hose on the other..
Sorry for all these dumb questions but I can't find what you guys are using.
TIA
Old Jul 18, 2007 | 05:28 PM
Tainted's Avatar
that grommet is $7 at the dealer, I ordered one yesterday
Old Jul 18, 2007 | 06:26 PM
JBsZ06's Avatar
What was the part number for the grommet that you ordered from the dealer yesterday?
Thanks in advance.
Old Jul 18, 2007 | 06:50 PM
Tainted's Avatar
I can get it for you tomorrow, jsut remind me
Old Jul 19, 2007 | 11:15 AM
3.4camaro's Avatar
breather.
Old Jul 19, 2007 | 04:49 PM
Tainted's Avatar
gave me the wrong damn part. anyone ever find the right part #?
