SLP Pulley install...how to.
Thanks
www.ls1howto.com has a good write-up on how to remove the stocker and install a new one. I'd also highly recommend buying an install tool from 618Hawk on this board...look around in the tools and fabrication section for details.
I will be purchasing a new GM bolt, So I remove the pulley, then I use the old bolt to tighten it to 240 ft lbs, then I remove it. And tighten the new bolt to 70ft lbs, plus 140 deg?
Is this about right?
http://i80.photobucket.com/albums/j1...alancer007.jpg
http://i80.photobucket.com/albums/j1...konia/bolt.jpg
http://i80.photobucket.com/albums/j1...alancer003.jpg
http://i80.photobucket.com/albums/j1...alancer005.jpg
