coolent coming from intake!!!!!!
Old Jul 14, 2007 | 06:43 PM
stripperz28's Avatar
Default coolent coming from intake!!!!!!
well i was pulling knock on my scanmaster and i thought it was the new slp pulley but turns out when we were looking at the motor,there was coolant coming from the center of the intake where it meets the head,my car has 29k and i take care of it.thank god i hooked up the scanmaster when i put the pulley on or i would have never knew my car pulled knock.i had the scanmaster off my car for a while cause it never pulled knock.should left it plugged in who knows how long i had this intake leak,why the hell did this happen?has anyone had this problem and what did you guys do to fix?is my intake warped?is this an excuse to get a fast?i already have a z06 intake?can i just replace those o-rings?
Old Jul 14, 2007 | 07:23 PM
bump bump bump!!!!!!!!!!
Old Jul 14, 2007 | 07:26 PM
studderin's Avatar
what did you do with the coolent tubes, one is probally leaking.
you got coolent down on you knock sencors.
Old Jul 14, 2007 | 09:03 PM
bczee's Avatar
There is no coolant flowing in from the Heads to the intake and back out, so the only sources that could flow coolant down in that direction would be the front coolant cross over pipe. Check it and o-ring/gasket.
The Rears most likely would not flow in that direction.
