Crossthreaded my harmonic balancer bolt
Hopfull you have a pulley with a keyway. So take the red sraw and get some WD40.pbblaster, any thin pen, lube. Down there.
see if the bolt will go in a little, should go in 1/4 turn then get locked up again. More spray. that tightn it agian, and keep working it, and you widen then locked up spot.
Get the FUBAR bolt out, then take a stock bolt, and make a chaser bolt. Put 2-3 cutoff wheel slots in the threads like a tap. And with greese put that in a few turns, take it out and see how it looks. clean it off. If the bolt is messed up. get another used crank bolt, and do the same. I know you probally dont have 2-3 stock crank bolts around, but ther softer then the crank So its best to use them. I hope the ARP isnt harder then the crank thread, you might be fucked then. One of the resons I like useing a softer bolt then the crank threads.
Its a ******* automotive forum, go nit pick somwhere else, like a english forum
But I had the correct thread size you say? Probably not because of a packaging error. A 5/16 SAE will thread into a 5/16 metric about a 1/4 inch before it stops - for example.
If it's in only a 1/2 inch you are lucky. I would just cut it off and drill it out then retap it. I would cut it before attemping to snap it off with a breaker bar.
Removing the fan shroud is fairly easy and quick and will get you extra room to work.
