Post Header Isntall Questions!!! Help!
Old Jul 16, 2007 | 01:05 AM
Blknight6989's Avatar
Default Post Header Isntall Questions!!! Help!
So yesterday i put on longtubes and an ory an let me tell u with the loudmouth its crazy loud!!! Iv noticed though that it idles realy rough though now an sounds more like a cammed car. I did the idle reprogram procedure i found on here but it still idles really rough. It also seems sort of choppy on the acceleration when im not on it just accelerating normal. Is this all normal or is there something wrong?? Im thinking the computer might just need time to learn the idle without cats or o2 sensors. Right now i just have the 02's plugged in the pipe but disconnected an just ziptied till i get extensions.....could this have anything to do with it?? Any help would be appreciated thanks alot!
Old Jul 16, 2007 | 01:12 AM
Vrbas's Avatar
Did you get the dummy sensors?
no not yet
Old Jul 16, 2007 | 01:36 AM
99NMB's Avatar
which o2's do you have unplugged...
Old Jul 16, 2007 | 02:57 AM
Black 99 Bird's Avatar
How many miles since the install?
Old Jul 16, 2007 | 06:24 AM
staringback05's Avatar
+1 more
Old Jul 16, 2007 | 09:03 AM
tylerdj's Avatar
Sounds like you did something wrong with your O2's.
Old Jul 16, 2007 | 01:06 PM
unplugged the top ones...i think this is my problem!! i think maybe 30 miles. im gonna go get extensions asap.
Old Jul 16, 2007 | 01:09 PM
Ceissus's Avatar
i dont think your front o2 wires will reach the header bungs without extensions. It sounds like you plugged your rear o2's into the headers
this is not good~
/scratches head
Blakbird24's Avatar
Restricted User
Yeah if you don't have the front O2's in, the computer will run in closed loop. That would probably result in alot of weirdness because the computer thinks there is a problem. I would avoid driving it without those front sensors plugged in.
Old Jul 16, 2007 | 01:21 PM
EvoWake's Avatar
any negative effects if you leave the rears connected?
Old Jul 16, 2007 | 01:34 PM
99NMB's Avatar
no the rear o2's are for emissions, you will get a ses light but have no adverse effects. just get some rear o2 sims, or have them tuned out...
Old Jul 16, 2007 | 02:09 PM
3.4camaro's Avatar
CORRECTION: Front O2 sensors not plugged in will cause the car to continually run in open loop. This will cause bad gas mileage and loss of power. Don't waste money on extensions, just cut up the O2 sensor wires and extend them yourself. It takes about 10 minutes and is really easy. Just extend 1 set of sensor wires about 2 feet and the others about 1 foot. Cover them in foil for heat protection and you're good to go. I did this last week. No issues.
If you installed an ORY, just unplug and uninstall the rear O2s and put them in your garage. They no longer serve a purpose for you. They are there to show the computer that the catalytic converters are doing their job. You don't have cats, so take 'em off.
ok so im running to speed inc tomarow after work an getting some extensions so that it'll be plugged into the computer an until then im not gonna drive it....thanks for all the help an everything should be fixed up by wednesday il let you all know how it goes. Oh an if anyone wants their car to sound like a race car at WOT i reccomend my setup....iv already scared numerous people!!
Old Jul 19, 2007 | 12:44 PM
OK so i hooked up the new o2 extensions so everything is plugged back into the computer. The car idles a little better but still runs kind of rough an at 1400rpm it kind of sputters an the whole damn car shakes but only at that speed. Then last night when it was raining i was with my friends an tryd to do a doughnut in an empty parking lot an couldnt even get the tires to break loose because of no low end acceleration unles my foots basically on the ground. Anyone have a clue what could be wrong because I dont wanna take it in to a shop if its something i could fix myself.
Old Jul 19, 2007 | 12:48 PM
haha wish i had saw this before i went to speed inc.!! owell...if i jsut take out the rear o2s then what will i plug the wholes in the ory with?? for some reason the ory came with wholes to plug in o2 sensors is this right?? these are the stainless xs headers an their great but are the holes for the o2's right??
Old Jul 19, 2007 | 12:55 PM
SladeX's Avatar
Front and rear O2 sensors are identical for the F-body cars.
Take your best 2 condition O2 sensors with the extensions, plug them into the header O2 bungs. Use anti seize on it and tighten it down real good. Until you get O2 sims (hard to find) or your rear O2's tuned out, plug in the worst 2 O2 sensors into the rear bungs OR simply find a bolt that size and plug them up.
Either way without cats the rears will tend to throw a code.
O2 extensions are much neater and easier to use than splicing.
Old Jul 19, 2007 | 01:20 PM
Thats what i did an ima have speed inc tune out the codes soon so no worrys on the codes but any idea why the cars running so hard??
