how hard is it to
Old Jul 19, 2007 | 09:53 PM
fuseone's Avatar
Default how hard is it to
how hard is it to get the stock catback off and install a slp loud mouth 2. and about how long does it take. or is there a write up on it how to do it
Old Jul 19, 2007 | 09:59 PM
Tainted's Avatar
bout 2ish hours in a driveway
Old Jul 19, 2007 | 10:03 PM
fuseone's Avatar
doesnt sound that bad from the looks of it to take of the stock one seems the hardest part am i right in saying that. and how would you take it off?
Old Jul 19, 2007 | 10:05 PM
Krab's Avatar
You can either cut it at the I-pipe that goes over the axle (most convenient place to cut), or you can unbolt the PHB, unbolt the passenger shock, swaybar endlink, wheel, and lower the axle a bit so you can pull the catback out the side of the car in one piece. You'll also have to jack your car high enough to give you the clearance needed.
Old Jul 19, 2007 | 10:06 PM
Tainted's Avatar
jsut cut the stock ****. you wont be needing it anyhow. its not hard
Old Jul 19, 2007 | 10:10 PM
fuseone's Avatar
will it be harder then get the lm2 installed wiht out removing alot of stuff then it is removing the stock cat back?
Old Jul 19, 2007 | 10:23 PM
Krab's Avatar
It will be easier to install the LM2 catback simply because it is not in one piece like the stock catback. You slip fit the different pipe sections together and clamp them. Much easier to do when working with the limited space.
Old Jul 20, 2007 | 12:36 AM
fuseone's Avatar
thanks both of you.
